Old May 14, 2015, 11:17 AM
SeByDocKy is online now
Find More Posts by SeByDocKy
SeByDocKy's Avatar
France, PACA, La Valette-du-Var
Joined Dec 2012
Mini-Review
Shen Qi Wei Allegro, 1/20th scale (Under construction)
INTRODUCTION
Here is a 1/20th scale RC model so called "Allegro" from Shen Qi Weil manufacturer. For less than 20 USD including shipping, you can have a first RTR RC moto working at 2.4G frequency band.
BOX CONTENT
+ 1 x Shen Qi Wei Allegro (with a 1S 120mAh LiPo ending with 2.25 2 pins connector )
+ 1 x Transmitter (using 2xAA batteries not included)
+ 1 x USB charging cable
+ 1 x Instruction manual (English/Chinese)
+ 1 x Screwdriver
OVERVIEW
- Front view
- Rear view
Both front and rear parts have shock absorbers
The moto without the LiPo weights 88.8g
and 92.5g with
Length dimension
The power switch is located beneath the saddle
On side screw to remove to access to the battery bay
The battery bay can probably welcome a longer LiPo up to 200mAh
- LiPo
a 120mAh 1S LiPo ending with a 2.25mm 2 pins connector
- Instruction manual
Disassembling
The main FC
Motors
A mini 6mmx12mm coreless motor is associated with the steering system
The main motor is a coreless 8.5mmx20mm
Transmitter
A basic 2.4G radio. The wheels don't provide a proportional steering: two buttons are pressed internal when your turn the wheel
2 speed modes can be selected as well as the throttle trimming via two pots.
The radio can be turned for left or right handling
FIRST USAGE
The moto is very fun when used on a relatively flat surface without too much granularity. Top speed can reach close to 20km/h and recover well sttandalone from sequence of saltos/crashes thanks to the inertia. The steering radius is not fantastic and you will need at least 8-9m to perform a full tour at full speed limiting usage into small flat. The control range was not fantastic, around 25-30m. I gess by installating the moto antenna differently, the control range can be improved. The playing duration was approximatvely of 5min with the shipped LiPo.
Shen Qi Wei "Allegro" Outdoors test (Courtesy Banggood) (8 min 7 sec)
CONCLUSIONS
For 20USD including shipping, you can't be wrong with this model if you want to try a first RC moto or plan to offerit as gift for a kid.
This model requiers a flat surface and a relatively large space so no ideal for small flat but more for large living-room or in outdoors conditions.
UNBOXING
Shen Qi Wei "Allegro" Unboxing(Courtesy Banggood) (13 min 47 sec)
PROS
+ Fun to pilot
+ Fast (~ 20Km/h)
+ Cheap RTR package
CONS
- No proportional steering
- Steering radius around 4m
- Radio control around 30m
This quadcopter have been courtesy provided by Banggood in order to make a fair and not biased review. I would like to thanks them for this attitude.
You can find it actually for 20 USD at
http://www.banggood.com/Mini-Motorcycle-2_4GHz-High-Speed-Racing-Car-RTR-p-970795.html
SeByDocKy is online now Find More Posts by SeByDocKy
Old May 20, 2015, 01:59 PM
BACKEMFNRG is offline
Find More Posts by BACKEMFNRG
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
Nice review, thank you!
BACKEMFNRG is offline Find More Posts by BACKEMFNRG
Old Today, 01:06 AM
SeByDocKy's Avatar
Joined Dec 2012
Discussion Tamiya Innovator 36" 1/20th Scale yacht Boomer1 Sailboats 13 May 18, 2015 03:09 PM
Sold 1:20th Scale Schooner Bluenose Fiberglass hull W.L Upshaw Boats (FS/W) 2 Apr 27, 2015 03:14 PM
Build Log Dumas 1/20th Scale Pt 109 jerry orfano Scale Boats 183 Apr 27, 2015 02:50 PM
Mini-Review UDI U941A "4-in-1" microquadcopter (under construction) SeByDocKy Mini Multirotors 7 Apr 16, 2015 05:11 AM
Sold Dumas PT 109 1/20th scale 48" price lowered to 250.00 jerry orfano Boats (FS/W) 0 Oct 20, 2014 08:31 PM
