Old Sep 23, 2014, 05:12 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Help!
Two servos don't 'move' together!
I have two NIB servos that when connected to a "Y" harness do not play well together....One will move, stop, then the other moves. I do have access to a HFP-25 programmer and have "reset' both only to discover nothing changes. I even tried connecting them to two different ports on a receiver (Specktrum 7100 and using a JR 9303 tx and DX8) and the same thing happens....I MUSTBE DOING SOMETHING WRONG!
Even tried different RX and TX, and one servo moves, stops, then the other servo moves to about 1/2 of the throw.
What is it?
Jerry
tailskid2 is offline Find More Posts by tailskid2
Old Sep 26, 2014, 02:27 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
I guess the $100 servos are junk then!
OR no one knows what is happening......
Old Sep 26, 2014, 09:40 PM
4*60 is offline
Find More Posts by 4*60
most exalted one
Canada, BC, Blind Bay
Joined Aug 2002
What servos? People don't know where to start. plug them into elev and ail channels and tell us if they move full on separate channels and........
4*60 is offline Find More Posts by 4*60
Old Sep 26, 2014, 10:30 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Servos are HS-5585-mn and I have plugged them in a variety of channels and one moves, stops then the other one moves!
Old Sep 27, 2014, 11:56 AM
Pilot232 is offline
Find More Posts by Pilot232
Pilot232's Avatar
United States, AZ, Peoria
Joined Jun 2004
tailskid2,
I have been watching this since you posted it. I wander why no response from
Hitec.!
Warm Regards,
Travis
Pilot232 is offline Find More Posts by Pilot232
Old Sep 27, 2014, 01:27 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
And that makes two of us!
Old Sep 27, 2014, 08:02 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
haven't give up - YET - so I tried a new Futaba R617FS RX with the same "Y" connector and BINGO! everything worked as it should.....then quickly plugged that connector into the Specktrum and ZIP.....one moves, then the other and now the second one decides NOT to return to neutral....move tx stick and after 3-4 times neither servo moves, then one decides to respond leaving the other behind, after a couple of microseconds, then that one moves.....I think I'm going to sell these servos and buy some JR servos......this is going on for too long!
Jerry
Old Oct 02, 2014, 03:20 PM
BobRCnut is offline
Find More Posts by BobRCnut
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
Sounds like maybe a standard servo plugged into a D-bus receiver? Does Spektrum have D-Bus or equivalent versions?
BobRCnut is offline Find More Posts by BobRCnut
Old Oct 02, 2014, 03:38 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
I think I found the trouble....my 6 volt battery was being charged by a charger that wasn't really charging it and for some reason would fail under a load....and those HiTec servos were taking a stronger load than the analog and digital JR servos.
Bought a new 6 volt battery and so far both HiTec servos are working as they should - but I'll keep testing them before flying with them.
Help! Servos Don't Move Waterwheel Hand Launch 4 Feb 11, 2014 11:09 PM
Alert Don't Move Your Threads Here Yet! - OK TO MOVE NOW! Steve85 Scale Kit/Scratch Built 9 Jan 21, 2014 07:26 PM
Sold I have 4 used motors I don't use, buy one, two, three or all four. I can split them. efx Aircraft - Electric - Power Systems (FS/W) 3 Nov 14, 2013 03:38 PM
Discussion Moving two-directional servo in only 1 direction ? piito DIY Electronics 17 Oct 24, 2013 09:52 AM
Elevator servos don't work on two planes? Condre' Electric Plane Talk 10 Dec 05, 2005 07:56 AM
