Old Nov 07, 2012, 12:45 PM
patrnflier is offline
Find More Posts by patrnflier
United States, IN, Elkhart
Joined Jun 2007
Hatfield "Little Bird" Arup type flying wing
I have just completed the build of a scale Hatfield Little Bird. This is a 52" inch .60 size flying wing is designed for glow or electric. I am waiting on clearance from the EAA, so I can publish the original Sport Aviation article from March of 1987.
A complete writeup on the Arup, Little Bird, and my build can be found on my website @ http://www.fancyflying.150m.com/Little%20Bird.htm
patrnflier is offline Find More Posts by patrnflier
Old Nov 07, 2012, 03:56 PM
nmasters is offline
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
That is one nice looking model.
--Norm
nmasters is offline Find More Posts by nmasters
Old Nov 07, 2012, 07:52 PM
Joined Jun 2007
Thanks for the compliment, we had a great time building the full size "Little Birds" and this one was a labor of love.
Old Nov 07, 2012, 11:08 PM
nmasters is offline
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Full size? I know a bunch of guys who would love to see an article about that. PM me if you're willing to write a little bit for publication in a newsletter.
--Norm Long time member of T.W.I.T.T.
Old Nov 10, 2012, 02:29 PM
Joined Jun 2007
full size
Here is a picture of the full size one flying. This is prototype number 3 of 5
Marty
Old Nov 10, 2012, 08:21 PM
nmasters is offline
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Great picture. It's a shame he didn't live long enough to refine the design to a final form.
Old Nov 11, 2012, 01:21 PM
Joined Jun 2007
That now has passed to Kevin Golden who lives in Missouri. He purchased the rights, plans and the prototypes. Number 5 was pretty well ready to clean up and put into production. The fuselage mold was finished and several were pulled off it. Kevin has disassembled number 4 and 5 and is in the process of rebuilding several areas to be more of a production plane than a prototype. This is so he can fly them and not worry about how lightly or crudely they were built.
Old Dec 06, 2012, 10:15 AM
Joined Jun 2007
It Flies!
The test flight has taken place and went without any mishap.
I am using a Turnigy G60 300KV with a Castle Ice 80II and a 7S 5000mah battery. I thought it was going to need a healthy bit of thrust. The airplane came in at just under 7lbs with battery. So, I set it up with a 15.5x13n standard prop. According to the calculator it would yield 40 amps and 80 mph. What I did not think of was SCALE speed......
It got off ok and did not need trim, however, when I leveled out and the speed increased it started pitching both up and down without input. When I reduced throttle to less than half it settled down and flew perfect. Increased power and it started the pitch up, pitch down cycle. Reduce power, equaled stable flight. So, I slowed it down where it wanted to be, and all was well.
After I landed I thought about it. I am at 1/4 scale and the full size Little Bird was a 70 mph airplane. If the 1/4 scale was doing 80 mph that would be three times greater than the scale speed should should have been. So, I changed props to a 15x10 electric. It reduced the amps to 29 from 40, which is still on the high side, but I still want some power for takeoffs in grass.
I also need to change the nose gear. I went to a trailing link and a soft tire. It proved to need more positive angle on the ground and the tire kept rolling to it's side. So I need to lengthen the strut and use a solid nose tire.
Other than that I think I will be ready for another flight. I just need to remember low and slow........
Marty
Old Dec 06, 2012, 09:48 PM
nmasters is offline
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
That may be the first time I've seen someone on this forum acknowledge that an airplane can be over powered
-- Norm
Old Dec 06, 2012, 11:58 PM
Stupot46 is offline
Find More Posts by Stupot46
I don't like your altitude
Stupot46's Avatar
Joined Sep 2011
-- Norm
Stuart
Stupot46 is offline Find More Posts by Stupot46
Discussion What type of flying wing is that? sfluck General Aviation 5 Oct 11, 2012 09:55 PM
Discussion Flying Flying Wing From Flying Wing TjW Flying Wings 5 May 19, 2012 09:52 AM
Question "bird" type flying wing, with or without reflexed airfoil? KenSt Flying Wings 6 Aug 31, 2011 06:22 AM
Discussion Arup S4 flying wing fritz2460 Foamies (Scratchbuilt) 27 Feb 17, 2011 05:41 PM
