Old Nov 11, 2003, 12:50 AM
Randy_H is offline
Find More Posts by Randy_H
Joined Feb 2003
Wally wing dihedral?
Hey, I'm building a 26" span wing from a Walmart Skyrider and I'm wondering if the wing has any dihedral? I looked through some of the threads and couldn't find any info about dihedral.
While I'm asking, what about incidence? Should the motor be tilted slightly up?
Randy
Randy_H is offline Find More Posts by Randy_H
Old Nov 11, 2003, 04:22 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
I built mine completely flat on the bottom. The reflex in the elevons provides some quasi dihedral.
A small thrust offset of the motor should be helpful. Putting the prop 1-2degrees higher than the back of the motor (front of the plane) will help keeping the wing from pitching down with throttle. Too much may cause the nose to pitch up. A lot depends on how far back the motor is located, and how high above the surface. Try to picture the thrust vectors of the wing and motor and have them intersect at the cg point or slightly ahead.
Gene Bond is offline Find More Posts by Gene Bond
Old Nov 11, 2003, 08:53 AM
Basil is offline
Find More Posts by Basil
GraysonHobby.com
Basil's Avatar
Grayson, GA
Joined Jan 2003
I always read folks giving the offset down and to the right?
Basil is offline Find More Posts by Basil
Old Nov 11, 2003, 10:43 AM
REVKEV6 is offline
Find More Posts by REVKEV6
massachusetts
Joined Apr 2003
thats from the front of the plane not the back. what you want with a wing is the thrust line of the plane to have some positive incedence for the wing. the way I think about it for a wing is if the motor is level you want the wing to have enough incedence to create lift. the last thing you would want is the motor level with the wing pointing down. unless you want to make a really expensive lawn dart
REVKEV6 is offline Find More Posts by REVKEV6
Old Nov 11, 2003, 01:24 PM
crashsiegel is offline
Find More Posts by crashsiegel
Tree? That's a Tx weed!
crashsiegel's Avatar
Central Texas
Joined Apr 2003
I built my Wally flat.
Works ok.
Crash
crashsiegel is offline Find More Posts by crashsiegel
Wally Wing V2 Construction Manual Site Up! hardlock Foamies (Kits) 20 Oct 24, 2001 12:47 AM
wally wing snaps in two on maiden flight dezflyer Foamies (Kits) 16 Oct 13, 2001 11:28 PM
WALLY WING new details (was: $10 Zagi killer success!) hardlock Foamies (Kits) 18 Sep 30, 2001 04:11 AM
Low Wing Dihedral? Barto Power Systems 6 Jul 03, 2001 09:31 AM
verifying wing dihedral question Mike C Power Systems 3 Jun 17, 2001 12:03 AM
