Old Feb 26, 2012, 02:41 PM
flycracker is offline
Find More Posts by flycracker
Rich
flycracker's Avatar
USA, SC, Lexington
Joined Sep 2001
DX6I back light mod
Best mod for the backlight? It is a really poor screen.
Rich
flycracker is offline Find More Posts by flycracker
Old Feb 26, 2012, 05:05 PM
freechip is online now
Find More Posts by freechip
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
There are two versions, EL Panel style and LED style. HK LED kit is so bright is shines threw the reflective backing making installation a breeze apparently.
I opted for the EL Panel style way before HK had a cheaper kit for sale.
freechip is online now Find More Posts by freechip
Old Feb 26, 2012, 05:36 PM
Rich
flycracker's Avatar
USA, SC, Lexington
Joined Sep 2001
Thanks, have been unable to find a good detailed install for the LED kit.
I am definitely mystified by the jumble of wires and connectors when the back of the case is removed.
Rich
Old Feb 26, 2012, 06:15 PM
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
The EL Glow panel I got came with DETAIL instructions on how to install and wire the kit. Wiring the any of these kit is fairly simple as all you need a connection to the power source and thats done at the ON/OFF switch of the radio or where the proper voltage can be found that will switch on and off when the radio is on or off.
As for install it that is up to you and your skillz..
The LED version is easier since it does not require modifying the LCD screen.
Take a look here, http://www.rcgroups.com/forums/showt...dx6i+backlight
Old Apr 13, 2012, 03:59 PM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
A rough guide here for fitting an EL pad...
You dont have to modify the display.. the pad shines through well enough...leave any reflective layer in place
Just a bit of chopping on the brackets that hold the display, so the pad fits in as well as the display
http://www.rcgroups.com/forums/showt...5#post21321100
davereap is offline Find More Posts by davereap
Question Turnigy 9X LCD Back light power consumption Jam1e Electric Plane Talk 14 Dec 26, 2011 12:26 PM
Sold futaba 9z wcII with back light joey1117 Aircraft - General - Radio Equipment (FS/W) 7 Aug 14, 2011 03:31 PM
Question DX7 Back Light Jvelo7892 Radios 1 Jul 01, 2011 04:44 PM
Discussion New AR Drone (i-drone) light mod bungle68 Multirotor Talk 3 Apr 13, 2011 05:30 PM
