Old Sep 07, 2003, 12:30 AM
IBbob31 is offline
Find More Posts by IBbob31
IBbob31's Avatar
I.B.
Joined Oct 2001
MEGA in Corona finally Works!!But HOT!
Bought new Corona to use my existing Mega 16/15/4, but after assembly it would only scoot around in ground effect! Was only pulling 12 to14 amps max. So stuck in an Atomic force /9t pinion and it worked. But after needing brushes i wanted to use the Mega, so bought some pinions from Robinson Racing, ended up with 12 tooth. With Atomic it hovered at 3/4 stick for 6 mim with 7c/2400. Now with same batts and re-geared Mega it hovers at 1/2 stick for 10 min,big improvement. Only problem is motor heating. 12v fan won't work with 7c pack tried it, but will 5v fan pluged into reciver cause any problems? What is everyone else useing? Will fan in reciever cause any problems as i am useing the BEC of the Jeti 40 Gold Label controller? Any advice will help. THNX BOB
IBbob31 is offline Find More Posts by IBbob31
Old Sep 07, 2003, 12:52 AM
Astro30 is offline
Find More Posts by Astro30
Astro30's Avatar
Honolulu Intl, Hawaii, United States
Joined Feb 2003
Cut a few holes in your canopy and get yourself a heatsink. I thought it was the B50 heatsink but I think it's the B40 heatsink you need, they're like $13 from www.aircraft-world.com just gotta get the size cleared up from some Mega ezoners
Oh yea, they 5 volt van will work in your rx, I've heard of many who done that...
Astro30 is offline Find More Posts by Astro30
Old Sep 07, 2003, 12:54 AM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
It's the B40 heatsink you need. It works really well on the Mega 16/15, but it's a tight fit.
Toshi
TMorita is offline Find More Posts by TMorita
Heat Sink for MEGA in Corona ericdod Electric Heli Talk 11 Apr 15, 2005 09:04 AM
Mounting Aveox or Mega in Corona a2zprod Electric Heli Talk 6 Nov 10, 2003 09:31 AM
Battery hot in Corona! johnvo Electric Heli Talk 20 Aug 15, 2003 08:02 PM
What Mega Brushless in Corona 120? ctoms Electric Heli Talk 6 Mar 28, 2003 12:35 AM
Balsacraft Hurricane finally works - (but so does the camouflage!) leccyflyer Scale Kit/Scratch Built 5 Jul 20, 2001 11:48 AM
