Old Jun 26, 2011, 01:35 PM
mrrocks42 is offline
Find More Posts by mrrocks42
Joined Jun 2010
rustler vxl clogging
My rustler has a problem that i discovered in the manuel was called clogging. Is this bad and if so could you tell me how to fix it?
mrrocks42 is offline Find More Posts by mrrocks42
Old Jun 26, 2011, 03:13 PM
Duster_360 is offline
Find More Posts by Duster_360
Texas
Joined Aug 2006
Its 'cogging'.....
It's usually caused by a battery that can't supply the amp demand. It can be caused by the firmware the esc is running if its a Castle esc.
What batteries?
Duster_360 is offline Find More Posts by Duster_360
Old Jun 27, 2011, 06:34 AM
Joined Jun 2010
im using a 7.2v 4200mAh 6 cell NiMH i think its about two years old with low to medium use
Old Jun 27, 2011, 04:34 PM
Texas
Joined Aug 2006
Its prob your batts - they can't supply the amps the setup is calling for, its pretty classic. You can try cycling the packs and see if they improve - NiMh doesn't like not being used and they may take a few cycles before they wake back up.
I have some 4000mah and 4400mah packs that don't cause cogging in my Slash, so its not that the packs are too small.
Old Jun 28, 2011, 01:45 AM
rcdude123 is offline
Find More Posts by rcdude123
United States, CA, San Jose
Joined Dec 2009
here, read this http://forums.thetoyz.com/index.php?showtopic=2532
rcdude123 is offline Find More Posts by rcdude123
Old Jun 28, 2011, 02:00 PM
Texas
Joined Aug 2006
^^^ That must be members only, you get an error trying your link.
Old Jun 28, 2011, 04:09 PM
Joined Dec 2009
darn, then make an account. the toyz is a really good forum.
Old Jun 28, 2011, 06:21 PM
Joined Jun 2010
im new to this how do i cycle the battery
Old Jun 29, 2011, 10:56 AM
Texas
Joined Aug 2006
Sorry, I already belong to more forums than I can keep up with. Just pick the important stuff you wanted OP to see and cut and paste it here....
Cycling is something done on a charger - once its set up, the charger discharges the battery at a selected discharge rate, waits for it to cool, then charges it at a selected rate. When its finished, charger waits a while for it to cool then discharges the battery again.
If you tell it 3 cycles, charger does it 3 times. Charger will typically keep track of the mah discharged each time and the mah input to the battery each time. You typically see these numbers increase for a few cycles and then they don't change - the battery is as good as its going to get at this point. Time to use it and see how it runs.
Discussion Performance Upgrades for Traxxas Stampede VXL, Rustler VXL, Bandit VXL, 4-Tec, Spirit hobbypartz HobbyPartz.com 0 May 26, 2011 02:30 AM
Discussion Bandit vxl or rustler vxl????? flysohigh Electric Power Cars 3 Mar 24, 2011 12:26 PM
Sold traxxas slash 4x4 and traxxas rustler vxl with mamba max, aluminum carbon fiber minit boss777 Cars - Cars and Parts (FS/W) 1 Mar 07, 2011 07:24 PM
Sold traxxas slash 4x4 and traxxas rustler vxl with mamba max, aluminum carbon fiber minit boss777 Cars - Trucks and Parts (FS/W) 3 Mar 06, 2011 08:10 PM
Sold Rustler VXL tires on New Rustler VXL wheels sdstick Cars - Trucks and Parts (FS/W) 3 Jul 21, 2009 10:53 PM
