Old Jan 17, 2011, 07:04 PM
get dustd is offline
Find More Posts by get dustd
get dustd's Avatar
Joined Jan 2011
Can I turn down a soldering iron tip?
I have a nice radio shack soldering station but I am finding out they don't make tips for it anymore. I have access to a lathe can I just turn down a bigger dia. tip or do they have some sort of conductive thermal coating on them i would remove? Wasn't sure where to post this but thanks for the help if anyone knows.
-joe
get dustd is offline Find More Posts by get dustd
Old Jan 17, 2011, 07:30 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
-joe
Hi Joe,
I also have the POS soldering station from Radio Shack, and discovered right after I bought it that Radio Shack does nor nor did they ever offer replacement tips for my model.
Be that as it may, do some searching to find who actually made that unit for Radio Shack and get the tips from them. They original manufacturer does offer replacement tips. Radio Shack elected not to carry them, however.
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Jan 17, 2011, 07:33 PM
Arkansas Travelr is offline
Find More Posts by Arkansas Travelr
God of Gravity Poisoning
Arkansas Travelr's Avatar
Joined Nov 2010
It depends, if the tip is pure copper yes but it will erode faster. If the tip is tinned iron clad copper no. Pure copper tips slowly dissolve as they are used an iron clad tip is more durable but only if the tinned cladding stays intact. You might be able to find a compatible set of tips. You could try Marlin P. Jones & Assoc. Inc. If they don't have tips that will fit they sell some cheap soldering stations. Their ZD-99 MINI SOLDER STATION 5-50 watt is only $15 and the tips for it are cheap.
http://www.mpja.com/solder_equipment.asp
Arkansas Travelr is offline Find More Posts by Arkansas Travelr
Old Jan 17, 2011, 08:14 PM
Marion is offline
Find More Posts by Marion
Marion
USA, NC, Hillsborough
Joined Oct 2003
I have turned down the copper tips. No problems. I needed the small tips for soldering SMD components.
Marion is offline Find More Posts by Marion
Old Jan 17, 2011, 08:23 PM
get dustd's Avatar
Joined Jan 2011
well the original tip will stay like it is. I will just step down the rest of the shaft and check the temp with a guy.
Old Jan 17, 2011, 08:49 PM
Hance is offline
Find More Posts by Hance
Expo is built into my thumbs
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
Is this the soldering station you guys are talking about. They do make tips for it I have some spares sitting here. I can probably get you a part number. http://www.radioshack.com/product/in...rodsPerPage=60
Hance is offline Find More Posts by Hance
Old Jan 17, 2011, 08:51 PM
Joined Nov 2010
If you have access to a lathe you might be able to fashion yourself some new all copper tips if the tip mounting base isn't too complicated of a shape to replicate. They will wear fast than your clad tips but they should work.
Old Jan 17, 2011, 09:25 PM
jizwood125 is offline
Find More Posts by jizwood125
Joined Jan 2011
yeah,i agree with u .
jizwood125 is offline Find More Posts by jizwood125
Old Jan 17, 2011, 09:51 PM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
I've used the Weller WLC100 for years. Have 2 at home.
They cost about $40
http://www.all-spec.com/products/WLC...FUS5KgodfzU2IQ
rick.benjamin is offline Find More Posts by rick.benjamin
Old Jan 17, 2011, 09:56 PM
get dustd's Avatar
Joined Jan 2011
No its not that soldering iron. Its got a little screen with a temp readout. ill try making a tip if we have some copper. it would be very easy to make. If not ill make another irons tip work because I need one in a few days so I dont want to order one. i didnt really like the pencil tip that much anyways. I like a small flat the best i think.
Old Jan 17, 2011, 10:15 PM
chrisf testpilot is offline
Find More Posts by chrisf testpilot
You can call me FANBOY!
Goodlettsville, TN
Joined Sep 2006
If you have an electronics supplier local, not radio shack or chain but an electronics supply house I would take the original tip down and compare it to an off the shelf unit before I started making one. As you may find it was probably manufactured by someone else.
chrisf testpilot is offline Find More Posts by chrisf testpilot
Old May 03, 2011, 12:32 PM
azonc is offline
Find More Posts by azonc
Joined May 2011
Hobby King Sell Hammer head soldering $3.78
azonc is offline Find More Posts by azonc
Old May 03, 2011, 04:52 PM
z-matrix is offline
Find More Posts by z-matrix
just look at it smokin'
z-matrix's Avatar
Joined Dec 2005
if you can get a pure silver rod like 99.99%
that may be your best option.
Z
z-matrix is offline Find More Posts by z-matrix
Old May 03, 2011, 08:52 PM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
Pure Copper is a PITA to turn and will very quickly bite. Could you use another material like brass or bronze?
lipoflyer is offline Find More Posts by lipoflyer
Old May 04, 2011, 12:13 AM
z-matrix is offline
z-matrix's Avatar
Joined Dec 2005
its said that weller tips are iron coated, so maybe it is worth trying an iron rod for tip.
iron tip for a soldering iron
Z
Iron soldering tip Joe Ford Batteries and Chargers 41 Feb 24, 2010 11:13 AM
Discussion need hammer tip for Weller 80W soldering iron burntkat Batteries and Chargers 13 Feb 27, 2006 06:36 PM
Wanted WTB: Hammerhead tip for Soldering Iron... redhatman Aircraft - General - Miscellaneous (FS/W) 6 Jan 04, 2006 04:32 PM
Source for a soldering iron and "hammer head" tip that will fit it? Art Horne Batteries and Chargers 5 Apr 16, 2003 08:46 AM
WTB: Hammerhead Soldering Iron Tip bradpaul Aircraft - Electric - Airplanes (FS/W) 2 Dec 27, 2001 02:58 PM
