Old Feb 08, 2011, 08:05 AM
vulpina is offline
Find More Posts by vulpina
France
Joined May 2006
oh yeah 13k$
vulpina is offline Find More Posts by vulpina
Old Feb 08, 2011, 11:24 AM
Old Man Mike is offline
Find More Posts by Old Man Mike
Old Man Mike's Avatar
Joined Sep 2007
A word of caution about VSWR meas. Lowest SWR does not always mean the best configuration, especially when it comes to circular polarization. You can easily push the antenna from good circular polarization to primarily horizontal or vertical polarization by distorting the elements for lower SWR.
You HAVE to model the antenna to understand what is going on.
OMM
Old Man Mike is offline Find More Posts by Old Man Mike
Old Feb 08, 2011, 11:52 AM
Mictronics is offline
Find More Posts by Mictronics
Joined Dec 2009
Mictronics is offline Find More Posts by Mictronics
Last edited by Mictronics; Jul 01, 2012 at 02:50 PM. Reason: Tired of RCG - Quality can be found at FVLAB
Old Feb 08, 2011, 01:31 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
OMM
An SWR reading really can be totally meaning less as well. I can put a 50 ohm resistor on the end of a coaxial line and get perfect SWR. We all know a resistor isn't an antenna.
Two antennas come to mind here: Yagis and helicals. Line up a set of yagi elements improperly and you can have a dummy load despite perfect SWR. Same thing with a helical. A poor shunt matched helical will have great SWR, but not resonate at all which I why I didn't cover it in the tutorial.
Still, nothing compares to a flight test (or a ground test). The skew planar wheel does wonderful on cheap RX units. Put it on a Lawmate RX and you have no signal at all. No modeling or SWR reading is going to tell you anything about a phenomenon like that.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Feb 08, 2011, 01:34 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Also, note that this antenna also exhibits some opposing polarization. A RHCP skew wheel will also radiate some LHCP. Granted it's low (maybe 12 db or so), but it does do this. If you look at the way the elements look when they are flat (as a figure 8) you will see why this is.
-Alex
Old Feb 08, 2011, 03:57 PM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Let me be sure, if I look at the SP from the side, and the rounded part of the elements mimics a standard screw thread then it is RH polarized, correct? Just making sure as when testing my helical + sp I have not been getting good results lately, and have been looking for the problem.
Is it possible I have HAM/ATV interference in my area that is CP in nature, and thus using CP over linear will actually yeild worse results? It seems teh 1st day I tested cp at my field it worked great, the next time terrible, exact same components just different planes and different days. am not sure it is the plane setup, as I think the setup on the second day was actually better in theory (more space, more separation, filtering etc whreas the stryker had none of those)
Derek_S is offline Find More Posts by Derek_S
Old Feb 08, 2011, 09:29 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Derek - I have had the same problem and am currently investigating the cause. The best way to determine polarization is to curl your fingers around any of the elements towards the center element of the coaxial cable. Thus you curl from ground to the origin so you fingers point to the origin point. What hand did you use? That's the polarization.
I'm certain the problem is in the helical. That microstrip match is fickle as can be. I just developed a more reliable match by using a tapered 1/4 wave metal strip. I will be adding it to the tutorial soon
-Alex
Old Feb 08, 2011, 09:41 PM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
Oh, nice, I will try changing the matching device.
And it looks like both my antennas are RH, so that shouldnt be it.
Old Feb 09, 2011, 01:33 AM
aSa2 is offline
Find More Posts by aSa2
Joined May 2010
-Alex
Lets take for example this antenna http://www.rcgroups.com/forums/showp...3&postcount=13 If I understand this method correctly - it is right polarisation?
aSa2 is offline Find More Posts by aSa2
Old Feb 09, 2011, 05:41 AM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
-Alex
So this design doesn't work well on the lawmate rx's? Is that correct?
gundamnitpete is offline Find More Posts by gundamnitpete
Old Feb 09, 2011, 06:26 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The skew planar wheel does not work with Lawmate RECEIVERS. It works fine with the transmitter, though. I have no idea why this is. Nobody seems to know. It does awesome with every other RX.
-Alex
Old Feb 09, 2011, 06:27 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Yes, that is RHCP. If you curl your fingers around the element with your right hand, they point to the centeral feed point.
-Alex
Old Feb 09, 2011, 06:29 AM
boopidoo is online now
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
So, is it a requirement to ave circular polarisation on both the transmitting and recieving end? What is the disadvantages and advantages of having a CP VTx & LP VRx antenna vs LP VTx & LP VRx antenna?
boopidoo is online now Find More Posts by boopidoo
Old Feb 09, 2011, 06:40 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Every system has distinct advantages and disadvantages. I will try to explain:
linear polarization on both sides - theoretically this gives the longest over all range under ideal conditions (which is seldom the case). However multipath interference and loss of polarization when banking the airplane cause loss of signal.
Linear on one side and circular on the other - Eliminates the problem with polarization loss due to banking. However there is a constant 3db drop due to polarization mis match and it will not reject multipath interference.
Circular polarization on both ends - Best choice for almost all FPV ventures. Does not lose polarization when banking and has excellent rejection of multipath interference giving the cleanest signal. Also excellent for high altitude. Theoretical range is slightly less than linear polarization, but is seldom realized.
-Alex
Old Feb 09, 2011, 06:46 AM
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Thanks!
So, for my setup (I'm using Lawmate and Airwave VRx) I guess would be CP VTx antenna and a LP VRx antenna (such as the biQuad or a patch). I'm not going for extreme ranges but I do like to bank hard when turning.
I don't think I'll re-invest in new VRx at this time.
But is the biQuad a closed loop antenna or not, ie will it work with Lawmate VRx?
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 53 Feb 21, 2015 07:02 PM
Mini-HowTo DIY Ground Plane omni directional RX antenna IBCrazy FPV Talk 60 Nov 19, 2012 06:11 AM
Discussion 900 mhz circular polarized antenna? g00bd0g FPV Talk 9 Aug 21, 2012 09:54 AM
Discussion 18dbi Circular Polarized Patch ? Coyote64 FPV Talk 3 Nov 10, 2010 04:59 PM
Question Circular polarized antenna question Sov4life FPV Talk 8 Mar 05, 2010 05:00 PM
