Old Dec 08, 2010, 12:28 PM
Joshbb is offline
Find More Posts by Joshbb
Ironbridge (UK)
Joined Jan 2009
hi,
are kda 20-22's ok with apc 12x38 props on a quad upto about 2kg auw? i did a search but couldnt find much info.
cheers.
Josh
Joshbb is offline Find More Posts by Joshbb
Old Dec 08, 2010, 02:09 PM
robin4 is offline
Find More Posts by robin4
Stavern/Larvik - Norway
Joined Dec 2008
Originally Posted by Joshbb View Post
hi,
cheers.
Josh
Hi
From personal experience, the kda 20-22's don't like those big props that much. Its no problem going up and doing a hover, but when descending you got a problem. The motors have low torque, meaning they will have difficulty slowing down. This gives unstable descends and you will even find that you will have problems getting the craft down if the wind is strong. Basicly you have to use alot of athority on the throttle stick.
The kda would be a good choice for a lighter craft (-1.5kg) since they are limited to 3s (by hk specs) on 10" props.
So you should rather try to go with a motor that can handle 4s and use 10" props if you are using bl-ctrl 1.2 - best option here that i know of is 2217/20 motors like turnigy/axi etc.
If you have the new bl-ctrl 2.0 you can go for a 35-xx size motor on 12" props.
robin4 is offline Find More Posts by robin4
Old Dec 08, 2010, 02:28 PM
Joshbb is offline
Ironbridge (UK)
Joined Jan 2009
Originally Posted by robin4 View Post
Hi
thanks for the reply Robin, I guess the 20-22's will stay in my spares bin then
Old Dec 08, 2010, 05:02 PM
simonjardine is offline
Find More Posts by simonjardine
Mikrokopter Australia ;-)
simonjardine's Avatar
Australia
Joined Apr 2008
Under Voltage
Customers who bought a v2.1 FC between end of 10.2010 and now.
Should check the following....
Some FC V2.1 are assembled with a 3,3V voltage reference instead of the default 3,0V.
This is IC7 on the FlightCtrl.
You can follow this link for better reference.
http://www.mikrokopter.de/ucwiki/en/...oltageSettings
I would recommend updating to V0.82b for anyone who has a V2.1 FC
Simon
p.s
if you have been seeing very short flight times before the undervoltage warning appears, this is probably the cause.
simonjardine is offline Find More Posts by simonjardine
Old Dec 08, 2010, 06:11 PM
dmsgodeep is offline
Find More Posts by dmsgodeep
Austin, Texas
Joined Apr 2009
Balance and yaw
I have a question about balance and yaw.
I have a new quad that is having some major yaw issues...but not all the time. I think it might have to do with my weight distribution...but I wanted to get other opinions.
I have it configured in X mode and when flying without the camera...I have the battery directly centered...and no yawing issues.
It's when I put the camera on that I have issues. I have it mounted straight out front in between the two front arms and I have the battery mounted on the back between the rear two arms to counterbalance the camera weight.
I have it perfectly balanced front to back and side to side...but my weight distribution is obviously way heavier on the Y axis than on the X axis. I don't know if this weight differential is what is causing unexpected yawing...or if perhaps it could be more related to weathervaining.
My goal was to keep everything up on the same horizontal plane as the arms so I don't have to use landing gear, like I do on my other copters that have the camera directly centered underneath (with no yaw issues).
Any thoughts?
Could there be a parameter setting that might off-set some of this yawing?
Thanks Guys,
Brent
dmsgodeep is offline Find More Posts by dmsgodeep
Old Dec 09, 2010, 12:48 AM
vpersiani is offline
Find More Posts by vpersiani
Creteil, France
Joined Nov 2003
Any thoughts?
Thanks Guys,
Brent
I have no direct answer to your question but have you noticed those new parts, supposed to improve Yaw control?
https://www.mikrocontroller.com/inde...020b124afef51c
vpersiani is offline Find More Posts by vpersiani
Old Dec 09, 2010, 09:19 AM
vfrjeremy is offline
Find More Posts by vfrjeremy
Dallas, TX
Joined Aug 2008
I too can attest to the fact that the 12's will work on the KDA 20-22Ls, but descents are not good at all. I fly 20-22s and have run both the 10 and 12 inch APCs. The 10's have been much better for me.
vfrjeremy is offline Find More Posts by vfrjeremy
Old Dec 09, 2010, 09:51 AM
va3mw is offline
Find More Posts by va3mw
va3mw's Avatar
Joined Sep 2008
The bar continues to rise:
Quadrotor Ball Juggling (a Preview) (0 min 38 sec)
va3mw is offline Find More Posts by va3mw
Old Dec 09, 2010, 10:02 AM
Greasetattoo is offline
Find More Posts by Greasetattoo
The tattoo guy
Greasetattoo's Avatar
USA, MN, St Paul
Joined Jun 2009
Did you ever try flying it with he wooden props as in the other photo?
Jim,
No, they are just for show....
Greasetattoo is offline Find More Posts by Greasetattoo
Old Dec 09, 2010, 11:20 AM
Peter Seddon is offline
Find More Posts by Peter Seddon
Solihull, England
Joined Jun 2004
The ESC will not absorb energy from the motor/prop to slow it down so fitting a larger prop with more inertia will take longer to decelerate.
Peter
Peter Seddon is offline Find More Posts by Peter Seddon
Old Dec 09, 2010, 12:31 PM
wizprod is offline
Find More Posts by wizprod
Denmark, Region Zealand, SorÝ
Joined May 2010
Peter
Yeah, this will hopefully be the next step in the BL's... Breaking until the desired speed has been reach...
wizprod is offline Find More Posts by wizprod
Old Dec 09, 2010, 08:06 PM
crashcam is offline
Find More Posts by crashcam
Florida
Joined Dec 2009
Just got my "Y" frame for a Co-axial I am building, it is a nice 72 cm motor to motor. This thing is Amazing!! Strong as an ox, light as a feather. Should haul just about anything.
I want to use a UAVX but unsure if it can handle a Y frame config.
Anybody try this yet?
crashcam is offline Find More Posts by crashcam
Old Dec 10, 2010, 03:45 AM
Solihull, England
Joined Jun 2004
And what will you do with the energy that needs to be dissipated ? Dump it to heat or back to the battery ? A Lipo may not like such charging pulses.
Peter
Old Dec 10, 2010, 08:18 AM
agressiva is offline
Find More Posts by agressiva
Eduardo
Brasil, RS, Porto Alegre
Joined Aug 2008
frame
hello brother ... where you bought this frame ?
its amazing ...
agressiva is offline Find More Posts by agressiva
Old Dec 10, 2010, 09:06 AM
wizprod is offline
Joined May 2010
Peter
I have no idea... I just know, it would be nice to have... I will let others do the engineering, it's safer that way :P
Discussion Mikrokopter Okto 2 build Roger_IIT Multirotor Talk 6 Feb 03, 2011 08:22 AM
Discussion Mikrokopter ME 2.0 Okto Build robin4 Multirotor Talk 16 Jan 12, 2011 02:07 PM
Discussion Mikrokopter / UAVP / quadrocopter / quadrotor build Arthur P. Multirotor Talk 16696 Nov 10, 2010 04:49 PM
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion PART 2 tend2it Multirotor Talk 2203 Nov 08, 2008 08:23 PM
