Old Apr 18, 2010, 09:28 PM
anathemapth is offline
Find More Posts by anathemapth
Los Angeles, CA
Joined Dec 2007
Help!
interesting servo problem
i was flying my merlin today and came across an interesting problem. upon plugging up a newly charged battery (i tried three), the rudder and aileron channel don't work at all, nor do they make noise. i tried swapping stuff around to no avail. i put pressure on the link, and then it work the whole time until i change the battery out. i can provide a video if this does not make sense. it is 100 percent repeatable. the "stuff' is:
merlin
ar6100e receiver
hs-55b sservos new 3s 480a batteries
dx7 transmitter
thanks for any help!
anathemapth is offline Find More Posts by anathemapth
Old Apr 19, 2010, 05:46 AM
freechip is online now
Find More Posts by freechip
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
Maybe the connection is not 100% good and the action of disconnecting the battery also affects the servo until you plug in a new battery then you need to check you servo connection.
You should take care of this problem before anymore flights as it would not be good to lose servo control in mid air.
freechip is online now Find More Posts by freechip
Old Apr 19, 2010, 06:16 AM
elcamino is offline
Find More Posts by elcamino
electromaniac
elcamino's Avatar
pittsburgh
check to make shure that the servo wirers arent backing out of the littel plugs. Sometimes the plastic clip that holds the wirers in the plug go bad and will let it back out when you plug them in giving a bad connection
elcamino is offline Find More Posts by elcamino
Old Apr 19, 2010, 07:36 AM
whitecrest is offline
Find More Posts by whitecrest
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
I'd measure the voltage on the receiver when you first plug in. Perhaps it's not getting enough from the BEC causing the erratic performance. Try a separate 4.8 volt receiver battery and see if you can repeat the fault. As above, I wouldn't attempt another flight until you track this problem down. Good luck with the trouble shooting.
whitecrest is offline Find More Posts by whitecrest
Old Apr 20, 2010, 07:41 PM
ed1978 is offline
Find More Posts by ed1978
ohio
Joined Jan 2010
its a connection problem......likely to the reciever.....try an extension cord....see if it goes away.....i had the same isue with a brand new reciever and brand new lipo......loose connection......i used an extension cord....it worked fine.....so then i used a locking clip to secure them......i have never had this trouble with any futaba plugs.....only hyperion......they seem to lack in quality of the connectors....and i also made sure i taped them up real good even if i used a locking clip.....too bad we all cant just buy stuff standardized.....this is the problem with stuff made in china.....
ed1978 is offline Find More Posts by ed1978
Old Apr 20, 2010, 11:39 PM
Los Angeles, CA
Joined Dec 2007
I tried all this and no dice. Thanks for the attempts. I will post a video later. Maybe I am not explaining it too well.
Old Apr 22, 2010, 01:28 AM
Los Angeles, CA
Joined Dec 2007
Video
Here is what I mean.
http://www.youtube.com/watch?v=CEEuKK-uIVw
Old Apr 22, 2010, 02:03 AM
unialfred is offline
Find More Posts by unialfred
unialfred's Avatar
United Kingdom, England, Milton Keynes
Joined Oct 2009
stripped servo gears?
unialfred is offline Find More Posts by unialfred
Old Apr 26, 2010, 10:25 PM
Los Angeles, CA
Joined Dec 2007
Unfortunately I don't think the gears are stripped. They move with no chatter. Plus it would be two on the same plane
Old Apr 26, 2010, 10:52 PM
bartricky is offline
Find More Posts by bartricky
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
I'll venture a guess..
Make sure that the control rods are not binding at all and move very free and easy.
Also bend the control surface hinges back and forth until they move easy.
bartricky is offline Find More Posts by bartricky
Old Apr 27, 2010, 05:52 AM
VROOMSTER is offline
Find More Posts by VROOMSTER
AMA #953123
VROOMSTER's Avatar
Eugene, ORYGUN
Joined Mar 2009
That is just strange. Call Ghost Hunters, I think it haunted.
VROOMSTER is offline Find More Posts by VROOMSTER
Help! First time builder, tail servo and/or gyro problem (I think) undinism Electric Heli Talk 3 Mar 25, 2010 07:41 PM
Discussion Servo Problem darmstrong Parkflyers 3 Mar 19, 2010 07:11 PM
Discussion new 5 in 1(msr)from horizon right servo problem? user0125 Micro Helis 2 Mar 11, 2010 01:30 PM
Discussion Interesting nano-tube phenomenon could have interesting implications for battery tech Sprydle Life, The Universe, and Politics 3 Mar 09, 2010 08:27 PM
Cool This looks interesting, a servo tester ken_nj Dock Talk 4 Mar 05, 2010 09:34 PM
