Old Sep 04, 2014, 06:52 AM
Joined Sep 2014
best fpv quad
Hi, im looking for the best cheap long distance FPV (real time feed and record) quadcopter for filming animals at a distance.
thank you in advance for replies.
RCandUAV is offline Find More Posts by RCandUAV
Old Sep 04, 2014, 12:20 PM
KD0ZET
Sheldon 78's Avatar
United States, CO, Divide
Joined Dec 2008
Sheldon 78 is online now Find More Posts by Sheldon 78
Old Sep 04, 2014, 03:34 PM
Keepin it real....
NutBag's Avatar
Australia, QLD, Brisbane
Joined Oct 2005
Mmmmmm.... Popcorn
NutBag is online now Find More Posts by NutBag
Old Sep 04, 2014, 04:01 PM
United States, FL, Land O' Lakes
Joined Mar 2001
If you want cheap and duration I'd say try a F450 clone frame with some Sunny Sky X3508S 700Kv motors and 12x4.5 APC MR props on 4s 5000mah packs. Any Simon K 30A esc would be fine. You would want to add some long landing gear and and an anti vibration mount under the frame for a Mobius or GoPro. If you want duration do not get a gimbal. Every extra ounce you carry equals less flight time.
For flight control I would suggest one of the many good APM 2.6 clones with a GPS/Mag unit. They are easy to set up and are very stable.
AdrianM is offline Find More Posts by AdrianM
Old Sep 05, 2014, 06:27 PM
Joined Aug 2014
What kind of flight times were you getting with that set up?
HeyDubYa is online now Find More Posts by HeyDubYa
Old Sep 05, 2014, 07:19 PM
Joined Mar 2001
I dont know. I was looking at building a duration quad and after a lot of research this was the set up I had settled on. I ended up deciding planes were more fun for long flights. This setup should fly 20 min easy. You will need to go to bigger props, lower kv motors and 6s batts to get more flight time. The problem is those big prop duration quads fly like crap...slow and sluggish.
My quad set up for aggressive, low, fast fpv flying. It flies about 10 min.
Old Sep 05, 2014, 07:30 PM
Joined Aug 2014
Good to know. Was looking to build and was thinking something close to that. Should be fun either way.
Discussion Best H-FPV quad for AV/AP? varis Aerial Photography 2 May 10, 2014 05:37 PM
Discussion Best FPV quad option for around $1000? a_fan Multirotor Talk 0 Apr 11, 2014 06:25 PM
Discussion Best Rx tx video for fpv quad? ROD GARCIA FPV Talk 11 Mar 30, 2014 04:19 AM
Discussion What is the best FPV mini quad at the moment? smallx Mini Multirotors 5 Feb 23, 2014 01:07 PM
Discussion Want a Quad FPV/Camera Platform what do you think is best? Bigfoot21075 Multirotor Talk 2 Nov 12, 2013 03:43 PM
