Old May 12, 2014, 09:47 PM
United States, NC, Charlotte
Joined Jul 2006
will this HK motor work with a t-28?
My motor died on my parkzone t-28. I have the factory plane and the standard ESC of 30A. Here is a motor I found. http://www.hobbyking.com/hobbyking/s...er_1320kv.html
Will it work with my ESC or will I need a new ESC? I am using 3 cell 11.1V 1800-2200 mAh lipos.
Thanks.
nelsonmay10 is offline Find More Posts by nelsonmay10
Old May 13, 2014, 12:30 AM
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
should work with your ESC. data posted there says:
Test Data @ 11.1v:
8x4.3 - 18.2A - 1000g Thrust
9x5 - 25.2A - 1310g Thrust
you may have to experiment (cautiously) with props past 9x5 in terms of how high in pitch and size you can go since that 25.2A is very close to your limit. a wattmeter will be needed.
cmdl is online now Find More Posts by cmdl
Old May 13, 2014, 07:38 AM
Capt Ed's Avatar
United States, NC, Wilmington
Joined Apr 2013
I use this motor in my PZ T-28 with the stock E-flite 30 amp and 3s 2200 battery. A little more expensive than your choice, but it works great and fits the T-28 motor mount without modification. I also found the PZ 9.5x7.5 prop fits the shaft without modification and performance is super.
http://www.hobbyking.com/hobbyking/s...er_1100kv.html
Capt Ed is offline Find More Posts by Capt Ed
Old May 13, 2014, 09:45 AM
Y=C+I+G
cmdl's Avatar
Joined Jan 2012
what is your amp draw?
Old May 14, 2014, 01:13 PM
Capt Ed's Avatar
Joined Apr 2013
Just got my watt meter, need to do some soldering and than I can answer question
Old May 14, 2014, 01:25 PM
Y=C+I+G
cmdl's Avatar
Joined Jan 2012
cool. will look forward to it.
i was curious since i saw a comment posted on the HK site:
"I have installed this motor on my Parkzone T-28 Trojan using a 10x7 prop (produces 320 Watts max). This has more power and a flight time of 7 min (down from 10 min on the stock motor which produced 218 Watts max). This has more power (hence a shorter flight time) and a bit heavier (so landings are a bit faster....just a little bit, not a lot so be prepared). A 11x7 prop is too big with the landing gear I have, but produces adaquate power with the 10x7 and a max draw of 31 amps."
the stock 9.5x7.5 should have a close amp draw to 10x7 the guy above was using. if over 30 then i recommend upgrading the ESC. but that depends on what your wattmeter says on your setup.
Old May 14, 2014, 01:45 PM
Capt Ed's Avatar
Joined Apr 2013
Checked 3 times, 280 watts with highest amp draw at 27.6. Since I don't push it, I'm probably ok with 30 amp esc. I may run WOT several times during flight but no more than 10 seconds or so.
thoughts?
Old May 14, 2014, 03:09 PM
Y=C+I+G
cmdl's Avatar
Joined Jan 2012
oh yeah. you're good with that. even if you run wot throughout, you're fine since it's 27A.
Help! Will this battery-ESC-motor-prop combination work? cschwab145 Multirotor Power Systems 2 Mar 27, 2014 05:28 PM
Discussion HK Multiwii 328P build, motors will not work ryanvv355 Multirotor Electronics 4 Mar 02, 2014 04:41 PM
Question Will a cox .049 work with this? walleyehunter34 Engines 2 Oct 29, 2013 06:59 PM
Question will this electric motor work in my boat??? howdidjobdoit Racing Boats - Electric 3 Sep 22, 2013 08:15 AM
Discussion Can THIS motor work with THIS plane? If not-can you show me an ARF that will work? zdsweet Electric Plane Talk 2 Jul 24, 2009 09:44 PM
