Old Mar 06, 2014, 09:48 AM
flying since 2000
sfluck's Avatar
Winterthur ZH, Switzerland
Joined Mar 2009
Profile question
Hi there,
Does anyone have the possibility (Profili?) to find out what profile that is in the attachment? I took a picture of the root rib (unbuilt kit) and converted it to black and white as good as possible.
I'd really appreciate a tip!
Stefan
sfluck is offline Find More Posts by sfluck
Latest blog entry: Flying the Spider X on the...
Old Mar 06, 2014, 11:58 AM
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
There's simply no way to spot it other than to compare overlays. I'd start off by measuring the point of maximum thickness. Then use Profili to draw out airfoils that look close and lay the rib over the printout to see which fits the best.
You might be better off to tell us what the model is and perhaps someone familiar with that particular design will know what the profile is supposed to be.
To start you off I'd going to suggest you look at the Eppler 201 and similar "200" family airfoils. It looks a little like those. Other family options are the Quabek airfoils in the 12 to 15% thickness range and the Selig 4233. Other than these starting points you'll simply have to shop down the airfoil aisle and pick out stuff that looks close and print it out. The bad news is that it'll take you a good hour or two to step through the whole library. The good news is that there will only be around 10 to 12 airfoils that are similar for you to print. So you won't use up too much paper.... But start with determining the thickness percentate. Then look at any option which is within 1% of that measurement and which appears to have the right shape.
BMatthews is offline Find More Posts by BMatthews
Old Mar 06, 2014, 02:19 PM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Also have a look through these to see if anything looks similar --
https://www.google.com/search?q=airf...w=1346&bih=655
eflightray is offline Find More Posts by eflightray
Old Mar 06, 2014, 10:34 PM
Grad student in aeronautics
United States, GA, Atlanta
Joined Oct 2010
One thing that might help is this digitizer program:
http://digitizer.sourceforge.net/
DPATE is offline Find More Posts by DPATE
Old Mar 06, 2014, 11:14 PM
"...certainty is absurd."
kcaldwel's Avatar
Joined Jan 2007
Here are some airfoils Profili came up with as being close to yours. I called your airfoil "Test airfoil".
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Mar 07, 2014, 06:21 AM
Canada, ON, St. Catharines
Joined Apr 2004
What is the kit? That may also help to identify it. Maybe contact the designer or is there a construction article somewhere?
wells is offline Find More Posts by wells
Old Mar 07, 2014, 07:31 AM
tau
Joined Aug 2006
Gents,
there is a quite handy web application tool that will search through its entire database for similar airfoils.
It is woth while remembering and saving this bookmark!
Regards, Tunc
tau is offline Find More Posts by tau
Old Mar 07, 2014, 03:14 PM
flying since 2000
sfluck's Avatar
Joined Mar 2009
Hi guys,
I'm building a K8 after a kit from Modellbaustudio Liening (hobby-land.de), which i think is a new edition of the Flair K8.
Thanks for the tips all!
Thanks Kevin for your comparing sheet! Thats really cool! It looks like the NA63A513 probably is the closest fit...
Tunc, i tried using this tool, but it wont let me although i have the newest version of the software needed... Weird.
Old Mar 07, 2014, 03:19 PM
flying since 2000
sfluck's Avatar
Joined Mar 2009
Oh gosh me again...
Silly me, I only googled for "Modellbaustudio K 8 airfoil"...
When i search for Flair K8, theres the info thats a HQ3.5/14. and judging by eye, that's probably it...
Shame on me, sorry guys!
Old Mar 07, 2014, 03:21 PM
kcaldwel's Avatar
Joined Jan 2007
Hmm. Your posted image file doesn't match very well with the HQ3.5/14.
Kevin
Old Mar 07, 2014, 08:50 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
And HQ3.5/12 perhaps? Or it may simply be yet one more kit maker's slightly butchered version of the "proper" airfoil. Lots of places where a little distortion could take place between the coordinates and the cutting.
Old Mar 07, 2014, 09:03 PM
kcaldwel's Avatar
Joined Jan 2007
I checked it against all the other HQ3.5 thickness forms, and they don't fit any better. If the image file is anywhere near close, and it is supposed to be an HQ3.5, there is a lot more "distortion" than I'd want to pay money for.
Kevin
Old Mar 08, 2014, 03:50 AM
hul
hul's Avatar
Switzerland
Joined Mar 2003
Profili reckons HQ2.5/12 is the best fit (second best...)
Hans
hul is offline Find More Posts by hul
Old Mar 12, 2014, 03:55 PM
flying since 2000
sfluck's Avatar
Joined Mar 2009
Just got a message from the producer of the kit, and it's a HQ 2.5/12.
Old Mar 12, 2014, 04:16 PM
hul
hul's Avatar
Switzerland
Joined Mar 2003
I win
Building a plane, weight, wingspan, profile questions kevinlongisland The Builders Workshop 2 Apr 15, 2004 08:19 AM
Question about "Profile" type Warbirds.... iam Foamies (Kits) 5 Apr 03, 2004 11:21 PM
Question Glow Morris Sledge Profile conversion question ?...please help Ulf Rieder Sport Planes 17 Mar 01, 2004 09:36 AM
Fan-Fold Profile A-10 question Gary Warner Foamies (Kits) 3 May 28, 2003 05:10 PM
Profile P-51 ---Question tim_j-rome Parkflyers 1 Mar 29, 2002 09:51 AM
