Old Sep 03, 2014, 03:47 PM
United States, IN, Carmel
The yellow anti-vibration mount is here and installed.
For my light TBS clone quad P66 and I8 in NAV works good. Very stable position hold. Returns quick to position when wind gusts push it and only 2-3 gentle oscillations when poked with fast manual input.
Very satisfied with my DOS!
/Dimitris
Dimitris76 is offline Find More Posts by Dimitris76
Old Sep 10, 2014, 02:58 PM
United Kingdom, Abingdon
Joined Dec 2012
problem with X8R receiver and fy-DOS
I have an X8r which i use with my taranis.
I have found i cannot arm the FY-dos using my X8r reciever
however if i plug in an old spektrum RX and connect to my taranis i have full control.
Sometimes (rarely) i am able to arm the dos with the x8r if i dissconnect it, arm with spektrum then unplug spektrum and plug in fy-dos?
i have no idea what is going on with this thing?????????
i have used it both with the plane firmware and multirotor fw
IT seems to work with the fixed wing fw but not the other.
i have howeer switched to using the old RX which as asked is spektrum and yes my taranis has both.
it has worked just fine with many models and the board will work with the d8r v2 and the d6r both of which are frsky but will not work with the x8r.
JaredReabow is offline Find More Posts by JaredReabow
Old Sep 10, 2014, 03:02 PM
Joined Dec 2012
UPDATE
i have now switched to my older d8r RX
the board arms and functions but i have an issue with flight.
I can take off and have some very minimal controls but overall the copter barely responds to my inputs. i have set rc gain to about double its original and P and I to maximum
the copter sloppily flys along and will not correct itself enouph to not crash.
I am using 4 800KV motors at 4s with 12" props
Discussion FY DOS autopilot saabguyspg UAV - Unmanned Aerial Vehicles 1175 Sep 10, 2014 02:57 PM
New Product Fy-41AP OSD & autopilot system is coming RC4YFPV FPV Equipment 316 Jul 11, 2014 02:16 AM
Discussion EZOSD sharing FY-GPS module with FY-DOS AP khaled_abobakr FPV Talk 4 Mar 03, 2014 05:10 AM
Discussion Fy dos FloridaFlyBob FPV Talk 2 Apr 05, 2013 04:43 AM
Sold FY DOS & FY Hornet OSD BNIB lemonsorbie FPV Equipment (FS/W) 2 Mar 19, 2013 10:42 PM
