Old Jan 29, 2013, 12:43 AM
Fremont, CA
United States, CA, Fremont
Joined Jan 2009
Question
Where to buy ornithopter drive
I've searched quite a bit for a place that sells just the drive mechanism for an ornithopter with no success.
Is there any place that sells just the drive and the fuselage frame?
Thanks.
djacob7 is online now Find More Posts by djacob7
Old Jan 29, 2013, 03:51 AM
therealthing691's Avatar
australia
Joined Apr 2007
.freeflight rubber band power yes high quality remote controll no
therealthing691 is online now Find More Posts by therealthing691
Old Jan 29, 2013, 10:10 AM
Fremont, CA
Joined Jan 2009
What???
Old Jan 29, 2013, 11:27 AM
Joined May 2011
Please check the next site . Drives are in the "shopping mall" section after that choose the first option on the left .Full metal gears drive is about 84 US$ , Plastic gears drive (only the last stage is metal gear is about 65.33US$There is even drive with frame in the section "upgrade" for about 93.33 US$. Also you can buy every component for this ornithopters separately in the "shopping mall" section last option on right - the prices are without shipping from South Korea.
http://www.magicbird.co.kr/
1 US$ = 1082.29891 South KR Won
Here it is in motion: http://www.youtube.com/watch?feature...&v=PkKhJxxOvNg
seagull10 is offline Find More Posts by seagull10
Old Jan 29, 2013, 11:36 AM
Push
XXXmags's Avatar
He means you can buy simple free flight ornithopters that run off a rubber band but you can't buy Hobbygrade ornithopters. The only large ornithopters in production that I know of are made by Sean Kinkade. Sadly this also applies to drive mechanisms..
You may be able to find someone that can sell you a Cybird drive mechanism but I don't know who. Your best bet if you want a high quality Mechanism is with an Silverlit I-bird (also called Airhogs V-wings) or an Avitron. The I-bot is a very light, 2ch infrared controlled ornithopter that has 4 clapping wings and weights 11 grams. Although it is a very good machine, it's drive mechanism is very limiting as it cannot take much more load than what it was designed to. As such you can't really use it to make a much heavier ornithopter. The best luck I've had the mechanism is with a 19.6 gram ornithopter, and even then I had to reinforce it with carbon fiber.
I can't say anything about the Avitron as I've never held one in my hands, but from what I can see it's a good machine. It's drive mechanism is different from that of the I-bot but it looks like it has the same or better quality. Take note though that the Avitron is LIGHTER than a I-bird. It weights aroun 8 grams, so I'm fairly sure it's drive mechanism can't take substantially more load.
More toylike ornithopters are the ifly vamp, the duckhunt ornithopter and the WooWee Dragonfly. Out of these the only one I know of that's in production is the duckhunt. The rest I don't know about. The Dragonfly is the heaviest as it weights around 20-25 grams.
If you're looking for a large drive mechanism, for an ornithopter heavier than 30 grams, you'll need to build your own..
XXXmags is online now Find More Posts by XXXmags
Old Jan 29, 2013, 07:50 PM
Fremont, CA
Joined Jan 2009
seagull10: Thanks for the link, but I can't understand anything on that page (Except the nice videos). Maybe I'll find a Korean speaking friend who will help me navigate your site.
Old Jan 29, 2013, 07:55 PM
Fremont, CA
Joined Jan 2009
XXXmags: Thanks for the interpretation; now I know what he means. You're both right: You have to buy a complete, large ornithopter just get the mechanism, or build one yourself. But it looks like Seagull10 has a good link to some South Korean made drives. I might buy one when I get to know what I'm doing on that site.
Old Jan 29, 2013, 08:41 PM
Joined May 2011
I don't understand Korean either So please contact them by email on English and they will answer you on English. They have done it in the past so I hope they will do this for you again.
magicbird777@hanmail.net
Old Jan 29, 2013, 10:44 PM
Fremont, CA
Joined Jan 2009
Good idea, seagull. I will do just that. Thanks!
Old Jan 30, 2013, 08:32 PM
australia
Joined Apr 2007
they will answer i have emailed them beforeabout a magic bird about a year or so ago cheers Brian
Old Jan 30, 2013, 08:43 PM
Fremont, CA
Joined Jan 2009
That's good to know. Thanks Brian.
Question Where to buy FS-TH9X-B Kev7274 Radios 22 Mar 03, 2013 10:30 PM
Discussion How to build (or where to buy) a 4-6 channel transmitter that is just switches? Bearsa LLC DIY Electronics 2 Jan 14, 2013 04:17 AM
Discussion Where to buy good quality rubber bands? rcmaverick Electric Plane Talk 21 Jan 09, 2013 08:45 AM
Discussion Where to buy this type of retract gear clive_fox Flight Accessories 6 Jan 07, 2013 01:58 AM
Discussion Kapton - where to buy ? lennyk High Performance 5 Jan 06, 2013 03:29 AM
