Old Dec 29, 2012, 12:29 PM
Joined May 2011
1S Lipo ... Any users? Servo recommendations?
Hi folks.
Please let me know your thoughts on sailing small boats on 1S lipo - I'd love to lose the weight of my regulator and go 2P if I can for my next build.
Thanks!
northernmike is offline Find More Posts by northernmike
Old Dec 29, 2012, 05:56 PM
Rusty
Rusty Nail's Avatar
Auckland, New Zealand
Joined Feb 2006
Works fine in a Footy.
All the receivers I have used AM, FM and 2.4gHz work ok and servos lose a little torque so size accordingly. Power consumption is less than on 2s too so batteries last longer. I have used Lithium Ion cells mainly, even a surplus small cell phone battery with protection circuit.. Then you have a charger too. For racing you can go down to a 150 - 200 mAh LiPo cell that weighs less than 10 grams with connector. This is the easiest way to cut weight in any small boat.
Yesterday I had a fire (little burnt balsa) in my RG65 after shorting the battery with a faulty charge plug, so I recommend a Polyswitch in the circuit to protect against shorts caused by faulty equipment and stalled large.sail servos that might otherwise be damaged.
Rusty Nail is offline Find More Posts by Rusty Nail
Old Dec 29, 2012, 06:03 PM
Joined May 2011
Thank you kind sir.
Very encouraging indeed!
Old Dec 29, 2012, 10:27 PM
Joined Jan 2007
If you are looking to shed weight for the C/L MM then I would suggest going the LiFe way..
The smaller Mah versions are quite suitable for Racing & fit well in most servo specs...
6.6v 1000mAh LiFe RX Battery Vapextech will do a full days racing... Only 50g
Zippy Flightmax @ 41g (700mah) are pretty good as well...
Cheers
John
waboats is offline Find More Posts by waboats
Reply With Quote  (Disabled)
Old Dec 30, 2012, 06:18 AM
Joined May 2011
Thanks John.... Will have a look.
I have enough 15g 350mAh LiPo that I could change one each race and charge at home, though - tempting to try.
Old Dec 30, 2012, 11:35 AM
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
Great idea. Where can you buy them in lots less than 100K....like 3 or 4 at a time?
FC
FoamCrusher is offline Find More Posts by FoamCrusher
Old Dec 30, 2012, 03:52 PM
Joined May 2011
Rusty what servos do you favour in your footies?
Old Dec 30, 2012, 08:36 PM
Rusty
Rusty Nail's Avatar
Joined Feb 2006
I am not familiar with small USA parts sellers, but RS and Mouser, should have them. Audio retail use small ones for speaker protection. Ebay and Amazon for mail order.
A 350 mAh Lipo should do a Footy in moderate conditions with a balanced rig for two hours.
As I only use balanced rigs, I can use small servos. A 9 -15 gm sail servo is possible provided you choose a highly geared slow type. Some of the more expensive brands like Hyperion have huge torque digitals up to 8kg/cm at 6volts! But I have used as small and cheap as HXT/TowerPro SG90 for rudder and sail servos! There are compromises to be made in sailing. You are not going to be able to sheet in running without a course alteration to unload the sail briefly. But these are a hardy and somewhat slower servo so no problems with gears. I have replaced the rudder and sail servos after a year or more of regular sailing with shorted or damaged boards that drive the servo hard over, but these Footies are sailed by lots of kids who know nothing of easing the loads on the servos. A 30 gm operating system in a Footy is easily possible! But maybe not necessary. Remember Roger's winning Footys weigh over half a kg!
Roger Stollery uses small servos on his large swing rigged Footys, but uses his Power Lever to increase torque when sheeting in. There seems little point to me to use traditional arm sail servos where torque is constant at the end of the arm!?
Discussion Foam Trainer Recommendations...3S 2200 or 1S 300 / 500 madmaxed Beginner Training Area (Aircraft-Electric) 4 May 01, 2012 07:27 PM
Discussion first time using a lipo larger than 1s...a little nervous...any tips? electricrc68 Batteries and Chargers 8 Apr 09, 2012 01:07 PM
Sold eflite 3.7v 1s 120mah lipo's tenergy 3.7v 1s 130mah lipo's nitrodude71 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Nov 17, 2010 12:05 PM
Discussion Any way to tighten up 1S LiPo connectors? Jim_Marconnet Scratchbuilt Indoor and Micro Models 6 May 22, 2010 03:21 PM
Sold 1s parkzone 3.7v 1s charger with five 1s lipo packs hacker002 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Dec 11, 2009 03:56 PM
