Old Jan 31, 2012, 04:02 AM
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
GWS HD props performance
GWS BL3008/16T test datas
PROPELLER (V) (A) Thrust=g; oz P=(W) Efficiency=g/w; oz/kw RPM
APC 12*8 7.4v 10.5 380.00g 13.40 77.70 4.89 172.49 4620
APC 12*8 11.1 24.7 800.00g 28.22 274.17 2.92 102.91 5700
APC 12*8 14.8 34.4 932.00g 32.87 509.12 1.83 64.57 6420
GWS HD-1280 7.4V 14.5 475.00g 16.75 107.30 4.43 156.13 4470
GWS HD-1280 11.1 25.1 917.00g 32.34 278.61 3.29 116.09 5775
GWS HD-1280 14.8 33.3 1174.00g 41.41 492.84 2.38 84.02 6465
So, how you like GWS HD props?
I like to see your test datas!
Pls post your experiences here.
GWS4CEO is offline Find More Posts by GWS4CEO
Old Jan 31, 2012, 06:24 PM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
The 9*7.5 HD is a superb prop for the 400-450 sized motors, but it is not widly used due to the hub design. Update that one to use the same kind of insert space rings that the 12*8 HD uses and I would buy 50 pieces at once. By not using the APC standard hubs on your props, you kill your market share. Its too bad, because really like your propellers.
JimNM is offline Find More Posts by JimNM
Old Jan 31, 2012, 10:14 PM
Taiwan, 北市
Joined Dec 2010
It'd not be hard if GWS decided to take your idea. This is a good idea for the GWS props EP8040, EP9050, HD9075 & EP1060. These props were all designed for direct driving. GWS have already released the 3-blade props with space rings in EP8040, EP9050 & EP1060. It's easy to apply the same hubs on these props.
Chen
twn Chen is offline Find More Posts by twn Chen
Old Feb 01, 2012, 07:46 AM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
What size motor that you use to fit in?
Which motor shaft size dia. in mm?
Old Feb 01, 2012, 03:06 PM
Re-Kitting Expert :o
Bullhead City, Arizona
Joined Jan 2005
Normal motor size would be 6mm but some are still 3mm and some are 8mm. That is why the inserts like APC uses and your 3 blade props use are such a great idea!
While on this subject, why not update the hub on the SlowFly props also? The small hub there makes it very difficult if not impossible to use with anything besides the threaded 3mm shafts of the gear drive units. I realize that the props were designed to be used with those but there are many people that use them on other motors because they love how the SlowFly props work!
GorillaBob is offline Find More Posts by GorillaBob
Old Feb 01, 2012, 05:53 PM
WAA-08 THANK FRANK!
JimNM's Avatar
Joined Jun 2002
the 9x7.5 HD is one heck of a good prop for 950 to 1100Kv motors on 3s. The Scorpion 2215-18 is my favorite motor in that size.
Old Feb 01, 2012, 09:04 PM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Glad to hear your comments.
Thank you.
Old May 25, 2012, 07:57 PM
United States, IN, Lebanon
Joined Oct 2011
Never tried the props but have used just about all others an APC seems to be the best of them.. I am glad to run across this post today as I was searching for a better prop that could compare to APC. I am going to get a few an see how they perform... APC needs some competition.
schusterjo is offline Find More Posts by schusterjo
Old May 25, 2012, 09:54 PM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
There is another sucessful example:
SkyArttech making a lot of small size toy RTF airplanes.
Their 4.25" propeller only give 50g thrust. Very difficult to fly their 120g little Cessna.
After change with GWS EP4530, they get very happy result!
In case that you have such similar samll RTFs, don't forget to try with GWS small propellers!
Old May 28, 2012, 09:27 PM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Who is flying 400 size airplanes?
Here is some reference for you to see why a toy is different to hobby products?
The first line 8X6 is a propeller which toy maker copy APC 8X6 prop, toy makers thinking they made their smart choice to save their budget.
But if you see the performance as below, I guess that you will rather change with GWS props.
Old Jun 01, 2012, 11:47 PM
GPT
GPT's Avatar
Sydney,Australia
Joined Dec 2004
Totally agree. My favorite choice of prop for GWS warbirds.
GPT is offline Find More Posts by GPT
Old Jun 15, 2012, 11:17 PM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Thank you for your comment.
Old Jun 15, 2012, 11:23 PM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
However, for small airplanes, GWS had many great choice for example:
http://www.gwsus.com/english/product...stem/edp50.htm
http://www.gwsus.com/english/product...tem/edp100.htm
http://www.gwsus.com/english/product...tem/edp150.htm
http://www.gwsus.com/english/product...tem/edp300.htm
http://www.gwsus.com/english/product...em/edp300h.htm
Old Jul 08, 2012, 09:34 AM
United States, FL, Pompano Beach
Joined Oct 2011
If it's not to difficult would someone post some pictures of these HD props. I am familiar with the slofly props that come in the kits have bought. Which is what the LHS (use to) have, but I hear reference (on other threads) to these HD props but have never seen any. Do they have a higher RPM limit?
I rewind motors and am always on the look out for different props to increase my test prop inventory for motor testing.
zeroback is offline Find More Posts by zeroback
Reply With Quote  (Disabled)
Old Jul 09, 2012, 12:30 AM
formosa
Joined Feb 2009
GWS HD propellers
hi zeroback,
GWS HD ( Hyper Drive) servies propellers can be checked out at link:
http://www.gwsus.com/english/product...peller_edp.htm
I have the propellers packing photo attached. Thanks for your support to GWS products.
gws roger is offline Find More Posts by gws roger
Sold 4 gws 9x5x3 props & 4 gws 9x5x3 pusher props ROCKY2 Aircraft - Electric - Multirotor (FS/W) 1 Nov 09, 2011 06:11 PM
Discussion Difference between GWS/EP and GWS/HD props? hhamzeh Beginner Training Area (Aircraft-Electric) 5 Jan 04, 2007 09:15 PM
For Sale PROPS! APC & GWS SLOW FLYER & GWS HD Dennis Everett Aircraft - Electric - Power Systems (FS/W) 3 Dec 29, 2006 08:41 PM
WTB: gws 7x3.5 HD or 8x4 HD props jlewis99 Aircraft - Electric - Airplanes (FS/W) 1 Sep 20, 2004 07:13 PM
FS: 7 GWS Props 1x 9x7, 3x 10x8, 2x 10x6 HD, 1x 11x4.7 FOR GWS EPS-400C Shaft $10! Nik-rc Aircraft - Electric - Airplanes (FS/W) 5 Jun 16, 2004 11:08 AM
