Old Jun 02, 2007, 01:40 PM
QuietRiot's Avatar
United States, ID, Ketchum
Joined Dec 2003
Question
Futaba Gy401/9254 combo - Do I need a Voltage Regulator?
My Trex 600 comes with a 5.1 v regulator designed to use between my digital servo & gyro (for most setups) I bought the 401/9254 combo boxed together and it does not mention any voltage regulator required per the Trex instructions. Is it needed with this combo or can the 9254 handle the straight 5.8 volts?
QuietRiot is offline Find More Posts by QuietRiot
Old Jun 02, 2007, 02:19 PM
QuietRiot's Avatar
Joined Dec 2003
Anybody??
Old Jun 02, 2007, 02:28 PM
Foam's Law
Joined Nov 2004
Yes, use the reg.
Davross is offline Find More Posts by Davross
Old Jun 02, 2007, 02:39 PM
QuietRiot's Avatar
Joined Dec 2003
My only question is why is it not mentioned anywhere in the manual. It even had a drawing of the 401 connected directly to the 9254. Since nearly every receiver puts out the same voltage, one would assume that a drop down is not necessary - at least with this specific combination.
Is it possible that when the 401 dip switch is moved to 'DS' that the voltage is stepped down internally?
Old Jun 02, 2007, 03:27 PM
A man with too many toys
United States
Joined Feb 2001
NO
If you look at Futaba’s specs for the S9254 servo it says 4.8v and no higher. 5.8v is way over the limit and will dramatically shorten the servo life.
Most helicopter flyers use a separate 5.0v regulator (UBEC) for everything.
http://www.gpmd.com/cgi-bin/wgpinf100p?&I=FUTM0224
RC
RC Man is online now Find More Posts by RC Man
Old Jun 02, 2007, 04:00 PM
Foam's Law
Joined Nov 2004
It is all down to the spec of the servo connected to the gyro, for instance the 9650 digital that a lot use for a 450 tail is 6V compatible. The 925* series of servos however do all state 4.8V max.
Kev
Old Jun 02, 2007, 04:17 PM
QuietRiot's Avatar
Joined Dec 2003
If the 9254 is a 4.8 volt servo, how much can it actually take before shortening it's life?
I did a voltage check with and without the Align regulator and there is surprising little difference:
Without the regulator, my voltage shows 5.87 right from the receiver
With the regulator, it reads 5.58
Is this enough to even make a difference? And why does it read so high when Align specs it at 5.1 volts?
Old Jun 02, 2007, 05:32 PM
Joined Jun 2007
Mine too... maybe Align has sent out several defective regulators. I'm thinking of making my own - any thoughts out there on doing this?
MommaSezNO is offline Find More Posts by MommaSezNO
Old Jun 02, 2007, 06:10 PM
Miami Florida
Joined Jun 2006
no you dont need it -- 5.1 volts is fine more that 5.4
use the stepdown for safety
http://www.readyheli.com/K10333A_5_1..._p/k10333a.htm
or the duralite version
or get a
arizona from fromeco -- Duralite- MPI -- linear regulator
this image might help
http://www.runryder.com/fastphoto/31...x_1en-9972.jpg
for all the DIY
DIY 6v -> 5.3V TR Stepdown
Goto ratshack and get a pack of 3a silicon diodes. Either of these part #'s will work:
276-1141 <-- I used this one
276-1144
276-1143
247-1661
The actual diode part number is 1n540x series diodes, encase you wanted to order from digikey or mouser.com. But it's cheaper to get it from ratshack because of additional shipping costs.
Get a short servo extension, and cut the red wire in the middle. Then solder and heatshrink the diode inline with the red wire. With diodes voltage flows only one direction, from the anode to the cathode (white stripe on diode). So be sure to align it correctly, or you won't get any juice flowing to the servo.
Because of the way a diode works they induce a voltage drop across the line under load, and it's about 0.7v. Under no-load you will generally see no voltage drop, or a quite small one < 0.2v. This is what steps down the 6v to ~5.35v which is safe for the 9253/4 TR servos.
You have two options for placement of the stepdown, between the rx and the gyro, or between the gyro and the TR servo. I chose to put the stepdown between the gyro and TR because I wanted a consistent voltage to the gyro. In theory the other way might cause cause calibration problems. Also the 401 is fine with a regulated 6v, which was another reason I chose to do it this way.
andres.c is offline Find More Posts by andres.c
Old Jun 02, 2007, 06:11 PM
QuietRiot's Avatar
Joined Dec 2003
Need what?
Old Jun 02, 2007, 07:27 PM
Rank Amateur
cadmonkey's Avatar
Maumee, Ohio
Joined Sep 2005
I haven't seen anyone come right out and say - you need it because the Align BEC outputs a voltage that is too high for the Futaba 9254. the graphics in adres.c's post indicates it though.
It's an Align setup item that's why your Futaba directions don't comment on it. If it's reading high - that may be because you don't have a load on it. I'd put a servo on it and turn on the radio to see what kind of voltage under load it produces.
cadmonkey is offline Find More Posts by cadmonkey
Old Jun 03, 2007, 12:31 AM
QuietRiot's Avatar
Joined Dec 2003
Hmmm, what about using a 5.1 volt Zener Diode rather than a Rectifier Diode. Zeners act as more of an actual regulator by design...though I noticed Align uses a 2amp 50v Rectifier Diode. Very simple circuit btw.
Not sure why folks even buy the $15 in-line regulators anyway when you can make your own with a $1.50 part. Besides the cost, too many plugs/harnesses is never a good thing anyway. Even if you have an Align (or other) regulator, it's best to desolder the diode and place inline into the existing servo or gyro wiring...just my two bits. -QR
Old Jun 03, 2007, 02:42 PM
Joined Jun 2007
Sounds like a great idea - like you said, the fewer the plugs the better - esp. on the critical tail servo (one less connection to work itself loose). Radio Shack only had the 3amp 50v Rectifier Diode, so I'm going with that one....
Old Jun 04, 2007, 12:40 AM
Got toys?
kenhiraihnl's Avatar
pearl city, hi
Joined Feb 2005
here's my .02...i bought one of these and wondered about the 5.6v output to the cyclic servos (fut9252 in my case)...
http://www.advantagehobby.com/produc...5&cat=0&page=1
so i researched a futaba forum, and found the following:
Hi Serafim,
The maximum regulated voltage should not exceed around 5.5 to 5.7Volts. The amount of torque and speed will increase approximately 10% at the peak of the batteries voltage.
I hope you find this information helpful. You can also reach our Futaba support team at 217-398-8970 opt 2, or via fax at 217-398-7721.
Sincerely,
Krysta Hunt
Product Development & Support Specialist
Futaba Service Center USA
quote:
ORIGINAL: SERAFIM
Hello from Greece
My question is the following. What is the maximum regulated voltage that I should use for Futaba digital servos that are rated for 4.8V only? I assume that it is higher than 4.8V, since a fully charged 4.8V pack has a higher voltage, but how high can it be? Also, should I expect more torgue-speed with this higher than 4.8 regulated voltage than the numbers stated on the servo specifications?
My servos are S9151, S9252 and S9650
Thank you in advance
Serafim
kenhiraihnl is offline Find More Posts by kenhiraihnl
Old Jun 04, 2007, 12:52 AM
Trons and Fumes
wrightme's Avatar
Fallon, NV
Joined Mar 2007
That does sound like a good idea. Something to think about if building such a circuit is how much current the zener will add to the mix. That may change the number of servos that the BEC will handle. Limit the current to the zener with a properly sized resistor.
For further engineering data, you can start here: Zener Regulators
wrightme is offline Find More Posts by wrightme
Sold Futaba GY401/9254 servo combo steve matteson Aircraft - General - Radio Equipment (FS/W) 2 Dec 13, 2006 01:10 PM
Sold Futaba GY401/9254 Excellent shape! 1.5 tesla Aircraft - Electric - Helis (FS/W) 2 Jun 07, 2006 09:42 PM
For Sale NIB GY401/9254 Combo chadtyro Aircraft - Electric - Helis (FS/W) 5 Sep 24, 2005 09:03 PM
Help! Do I need a voltage regulator? Armchair Bronco Batteries and Chargers 4 Jun 12, 2004 03:09 AM
[B]FS: Futaba GY401/9253 Combo Like New !![/B] System27 Aircraft - Electric - Helis (FS/W) 6 May 15, 2004 11:42 AM
