Old Jan 24, 2007, 09:05 PM
let it fly!
EWo_Ge's Avatar
Germany, Dieburg in Hessen
Joined Oct 2006
What's more stable: 2 blades with flybar or 3 blades without???
Hello all -
Inspired by some successfull builds of multibladed rotorheads, I would like to design and build one myself.
The four blade design would probably the easiest one, since I would'nt need to modify the swash plate.
But the five bladed version I've seen from Super Hornet realy takes the cake. A three blade design would be great for a LAMA scale build
Here are two basic questions:
- What is based on your experience more stable in flight: a two bladed head with flybar or a three bladed one without the flybar?
- Am I right in the assumption, that (with the same headspeed) I need a shorter servo throw since my lift is higher?
Any input and/or other experiences are welcome.
Thank you,
EWo
EWo_Ge is offline Find More Posts by EWo_Ge
Old Jan 24, 2007, 10:20 PM
Singapore
Joined Jan 2004
Hi EWo_Ge
Thanks for the good words... have u seen my 6 bladed yet?
OK... for 2 bladed with flybar, it is the flybar+weight (weight from paddles) that behave like a mechanical gyro for the cyclics (both elevator and aileron). It looks simple but it get the job done pretty well.
So now if u were to compare 3 bladed with cyclics gyro...and assuming everything is done properly, I would guess it perform as good as 2 bladed with flybar.
Even 3 bladed without gyro is still flyable but the stability will loose out to with flybarred version BUT the stability is still better than 2 bladed flybarless...
Compare normal flybarred and flybarless with direct link, the "throw" for direct link will have high pitch changes to the blades (pitch in terms of collective and cyclic). That is why many who tried flybarless can tell u that the cyclic response is too sensitive if u just use normal settings. With that, u want to have small movement and finer resolution. To achieve that, u use shorter servo or/with higher Expo/Dual Rate.
SH
Super_Hornet is offline Find More Posts by Super_Hornet
Old Jan 25, 2007, 01:17 AM
Magic Blue Smoke costs to much
jason H's Avatar
Melbourne, AUSTRALIA
Joined Dec 2004
All this talk of multi blade heads, I want one but lack the brain cells.
jason H is offline Find More Posts by jason H
What's More EXPENSIVE - GOLF - WOMEN or R/C? doberman Electric Plane Talk 51 Dec 08, 2005 06:03 PM
Atlanta Hobby or Home Depot, what's more tempting? LouMelancon Atlanta Area RC 8 May 03, 2005 01:19 PM
What's the diff 'tween 2/3A and AA packs? Ron D Batteries and Chargers 5 Aug 09, 2003 09:39 AM
What's more important for a fast climb Prop Speed/inflight thrust? soholingo Electric Sailplanes 17 Aug 19, 2002 05:28 PM
What's your 10-cell brushless setup for your 3.5-4 pound plane? Mitch G Sport Planes 19 Feb 05, 2002 11:08 PM
