Old Feb 22, 2002, 03:34 PM
N. Andover MA
Joined Sep 2000
charging a lead acid battery
I found a 12V 33amp-hr lead acid battery. Can I charge it via my CG-330 Hitec charger using my car battery as an input source?
Or, does anyone know of a way to make a charger? Perhaps with a computer P/S...5V....12V....etc???
Thank you all in advance.
cenman is offline Find More Posts by cenman
Old Feb 22, 2002, 06:45 PM
Worcester, MA.
Joined Nov 2001
Why not go to WalMart and buy a charger? There pretty cheap, probably in the $20.00 range, and you won't have to worry about blowing up that battery.
DBCherry is offline Find More Posts by DBCherry
Old Feb 23, 2002, 01:58 PM
stegla's Avatar
Guernsey
Joined Jan 2002
Is it sealed? Or can you top it up with distilled water?
A sealed lead-acid battery will need a dedicated constant voltage charger to avoid overcharging and drying out the 'gel'. IIRC the constant voltage is set to 14.4V.
If it is not sealed, then a regular car charger can be used.
Steve
stegla is offline Find More Posts by stegla
Old Feb 23, 2002, 09:26 PM
San Antonio, Texas USA
Joined Feb 2001
What about if it is sealed. I have one and can't figure out how to charge it?
cruzomatic is offline Find More Posts by cruzomatic
Old Feb 24, 2002, 05:41 AM
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
The best bet is to get a proper charger that's intended for deep cycle/sealed/gel batteries. Mine cost 19.99 (=$28.60) about 6 years ago, and it's fantastic - microprocessor controlled, you can leave any battery permanently connected if you want as current is continuously monitored & adjusted.
Car battery chargers are cheap & easy to get, but usually way too aggressive.
Bill Glover is offline Find More Posts by Bill Glover
Old Feb 24, 2002, 10:45 AM
chrisc's Avatar
canada
Joined Sep 2000
charger
My Orbit V6.0 charges Lead Acid battery up to 70 amps capacity. Trouble is you need a 12 V 15 - 20 Amps power supply to power it.
chrisc is offline Find More Posts by chrisc
Old Feb 24, 2002, 10:10 PM
MK
NJ
Joined Feb 2001
Ace CVC (for constant voltage charger) charger specially designed for gel cells and lead acids. Sealed or unsealed is insignificant.
Or, if you are good with electronics I believe there are a few schematics of easy to build constant voltage chargers for gel cells here:
http://www.glasgow-barnstormers.org.uk/howto.htm
The site was provided by someone here on the Zone.
MK is offline Find More Posts by MK
Charging lead-acid battery robster94gt Batteries and Chargers 7 Dec 05, 2005 09:26 PM
charging a deep cycle lead acid battery dave morris Batteries and Chargers 6 Sep 10, 2004 01:29 PM
Charging sealed lead acid battery motorhead Batteries and Chargers 6 Jan 14, 2004 07:50 AM
Charging a lead acid battery Ed F Batteries and Chargers 3 Apr 06, 2003 09:24 AM
Lead acid battery charging domlou Power Systems 6 Jun 20, 2002 01:00 PM
