Old Oct 26, 2004, 06:52 PM
Gizzmo0411's Avatar
United States, TX, San Angelo
Joined Mar 2004
AXI Stuttering...
I've just setup my new AXI 2212/34 with a 3s 1500 mah lipo through a pheonix 25 esc, and the motor won't start. It stutters for a minute...then stops. I'm throwing a 10x4.7 APC prop. Anyone know why this is??
Gizzmo0411 is offline Find More Posts by Gizzmo0411
Old Oct 26, 2004, 07:43 PM
Lexington , Kentucky,
Joined Jun 2004
On a foamy??
Racekannon is offline Find More Posts by Racekannon
Old Oct 26, 2004, 07:50 PM
Gizzmo0411's Avatar
Joined Mar 2004
Yeah...
It's on a Tuff-E from Northeastern Sailplanes, it's a 13-14 oz. EPP foam plane.
Old Oct 26, 2004, 08:05 PM
[This space for rent]
macr's Avatar
Newcastle, NSW, Australia
Joined Aug 2003
Sounds like the Phoenix. I had a lot of issues with an Ultrafly outrunner and the Phoenix 25. What version of firmware are you running. I think they are up to 1.07b last time I looked and it nearly has it running correctly. Also check your timing.
macr is offline Find More Posts by macr
Old Oct 26, 2004, 08:07 PM
Gizzmo0411's Avatar
Joined Mar 2004
In other words I need to get the USB link for it to work right?
Old Oct 26, 2004, 08:15 PM
macr's Avatar
Joined Aug 2003
If it is programmable, then yes. Latest version is now 1.08b, which I am currently downloading as I type. Updates can be found at
http://www.castlecreations.com/downloads.html
The USB link isn't all that expensive and I fell is worth the money.
Old Oct 26, 2004, 08:28 PM
Slope Stud
ORANATOR's Avatar
United States, CA, Oceanside
Joined May 2001
sounds like a cold solder joint.
Double check all your connections.
ORANATOR
ORANATOR is offline Find More Posts by ORANATOR
Old Oct 26, 2004, 09:08 PM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
ORANATOR
Resolder ALL connections.
hoppy is offline Find More Posts by hoppy
Old Oct 26, 2004, 09:11 PM
Sweet!
Quacker's Avatar
United States, CO, Longmont
Joined Jul 2001
If you spin it by hand when it's doing that, does it start then? If not, the motor may have a shorted phase. Another way to tell is to disconnect the ESC and spin it. If it feels stiff and stops immediatly--it's got a shorted wire in one of the phases.
Q
Quacker is offline Find More Posts by Quacker
Old Oct 26, 2004, 10:41 PM
Kevin Murray's Avatar
USA, NC, Greenville
Joined Dec 1999
Gizmo - You can reprogram the settings without the link. I would look into the solder joints first, then set the timeing advance lower than the default setting.
Quacker - A shorted phase will make the motor turn stiffly ? I wasen't aware of this, untill now.
Kevin Murray is offline Find More Posts by Kevin Murray
Old Oct 26, 2004, 11:07 PM
Sweet!
Quacker's Avatar
Joined Jul 2001
Sure. You can try it yourself by shorting any 2 phase wires together and spinning it(a prop helps). The motor acts like a generator but all the energy will go into the short. Try it--you'll be amazed.
Old Oct 26, 2004, 11:16 PM
USA, NC, Greenville
Joined Dec 1999
I just tried it. Thats pritty cool. Thanks.
Old Oct 26, 2004, 11:31 PM
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
My 2212-26 AXI starts and runs just fine on the default PHX25 settings (not sure what programming mine has... I bought it several months ago. AXI recommends advanced timing settings, but I left mine at default. I tried the advanced setting but could not see any significant difference in the starting or running ( I didn't do any test stand measurements). I'd make sure the PHX is set to factory defaults and start from there. If it won't start without hesitation, then I doubt the ESC is the problem.
Tom Frank is offline Find More Posts by Tom Frank
Old Oct 27, 2004, 07:07 AM
Gizzmo0411's Avatar
Joined Mar 2004
I've tried with the default settings...one thing that I've heard...some of the PHX 25's, particularly if you've purchased it a while ago has a software problem that can be fixed with a download from the CC site. So I'll try that fix first, if it's not that, then I'll send the motor back. I've checked and rechecked the solder joints, and that's most definitely not the problem.
