Old Jan 28, 2002, 10:15 PM
Villa Park, CA
Joined Dec 2001
Can I use a Kontroniks 3-SL-70-6-18 with a Hacker motor
Just wanted to know if I could use my 3-SL 70 with a B50-18S Hacker motor. Also does the hacker put out more power than an Aveox 1412/2Y on 16 cells in a Midi fan?
Thanks JJ
jet jock is offline Find More Posts by jet jock
Old Jan 29, 2002, 12:07 AM
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Kontonic ESC
Joe, Yes you can I'm flying my F-86 B50-13XL with the 3SL-70-6-18 Kontronic ESC. Works fine I'm also using one with my B50-18S in my Midi powered F-86. I have one of the new Hacker/Jeti 77AMP 30 cell ESC on order to try.
Bob Ruff
bruff is online now Find More Posts by bruff
Old Jan 29, 2002, 08:22 AM
Jim Phelps's Avatar
Elizabethtown/Ft. Knox, Kentucky, United States
Joined Jan 2001
Bob,
Who did you order the Jeti from. I have the 70A opto in my 125% F-18 with the B50 18S and it shuts down after about 2 mins. I think because of the thermal safety.
Jim Phelps
Jim Phelps is offline Find More Posts by Jim Phelps
Old Jan 29, 2002, 08:46 AM
Electriaddict
dorysch1's Avatar
Melville Saskatchewan Canada
Joined Mar 2001
Hi Jim where do you have the controller mounted? behind the motor in the jet stream?
dorysch1 is offline Find More Posts by dorysch1
Old Jan 29, 2002, 10:37 AM
Flying Welder Pilot
Plane Crazy's Avatar
Reno, Nevada
Joined Jan 2001
Jim-I was having similar problems with the shut down with the Jet 40 3p opto on Astroflight 805s. It was more of a receiver glitching problem for me. Now I wrap my receivers in aluminum tape on all my Jeti applications and have never had the problem again.
Gordon
Plane Crazy is offline Find More Posts by Plane Crazy
Old Jan 29, 2002, 01:15 PM
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Re: Can I use a Kontroniks 3-SL-70-6-18 with a Hacker motor
Originally posted by jet jock
Just wanted to know if I could use my 3-SL 70 with a B50-18S Hacker motor. ...Thanks JJ
Yes it works very well, it's a very good match for the Hacker, I have a similar combination. The Jeti 70A opto also works very well, but it's a few percents less efficient... The newer Jeti's are more efficient, they will be available inthe US in a few months.
Herb is offline Find More Posts by Herb
Old Jan 29, 2002, 04:55 PM
Jim Phelps's Avatar
Joined Jan 2001
dorysch1,
No it's not in the air stream. The first 2 flights were on a day when it was 25 degrees and no problem. Last flights temp. was up in the 60's.
Gordon,
It worked for over 2 mins., mostly full bore before it quit. Do you think it was a radio glitch shut down?
BTW it's putting in ~950W.
Jim Phelps
Old Jan 29, 2002, 05:12 PM
Flying Welder Pilot
Reno, Nevada
Joined Jan 2001
Jim_ My Jeti's would run perfect for a flight and then quit on the next, then quit after 2 minutes, even had them quit in the middle of a take off run. When I tryed the foil around the receiver it started working fine everytime. Could not explain why.
Gordon
Discussion can you use the kontronic jazz 40 6 18 with neu 1107 -2y ? djdaveq Mini Helis 1 Jun 26, 2006 08:15 AM
F/S Kontronic 3 SL 70-6-18 Opto ESC Aobid Aircraft - Electric - Airplanes (FS/W) 10 Aug 12, 2003 09:15 AM
3 SL 70-6-18 ESC Issue Aobid Kontronik 4 Jul 11, 2003 07:31 AM
FS: Kontronik FUN480/33 with Kontronik GB + SL 40-6-18 Atindra Aircraft - Electric - Airplanes (FS/W) 3 Jun 12, 2003 08:29 PM
Can i use an FMA Direct mini 30 esc with an 0.5, 7.2V, 3:0:1 ???... ermit Electric Sailplanes 2 Jun 04, 2002 05:27 PM
