Old Apr 15, 2014, 04:39 PM
Joined Nov 2011
Originally Posted by tdford View Post
Tspine: is this the fan you're using? http://www.extremerc.com.au/estore/i...oducts_id=1116
Also - on stock 4s motor?
mark did not say what het motor he uses on the 12blade 64mm with 4s.
I think he uses that HET 2w20, 3450kv.
The het 2w20 is perfect for the new 70mm Wemo evo, with 4s.
So I believe it is also a good match for
the down size and high blade count 12b 64mm with 4s
Those two fans , even different size but might have similar load on the motor,
9 blade 70mm rotor vs. 12 blade 64mm rotor :-)
flylow2011 is online now Find More Posts by flylow2011
Old Apr 15, 2014, 08:10 PM
FireHawx
United States, FL, Jacksonville
Joined Oct 2011
Yeah, I am curious as to the motor used in that Vid too?
FireHawx is offline Find More Posts by FireHawx
Old Yesterday, 12:36 PM
United States, UT, St George
Joined Jun 2009
I got my 3S version yesterday. Would I be ok running 35c batts in it? I'm looking to order some from HK today. Also any suggestions on fans that might be an upgrade over the stock?
reignman40 is online now Find More Posts by reignman40
Old Yesterday, 04:05 PM
Comin' in HOT!
tdford's Avatar
United States, CO, Denver
Joined Dec 2012
I'm going to add some skids this week.
Got the skids added and painted.
tdford is online now Find More Posts by tdford
Latest blog entry: Freewing 64mm F-22 Raptor
Old Yesterday, 04:06 PM
Comin' in HOT!
tdford's Avatar
Joined Dec 2012
Originally Posted by FireHawx View Post
Any good video of the flights td?
Got a quick video too. I didn't edit the flight, came down a bit early. Was just trying to get some basic footage. This was it's 10th flight. I'm really liking this F22, she can be fast and keep you on your toes, as well as slowing down easily. The flight after I stretched the flight to 4:00min with no problem. She's fast enough that I can lay off the throttle quite a bit and don't have to keep it WOT the whole flight.
Freewing F-22 EDF hand launch HD video 1 (3 min 40 sec)
Old Yesterday, 04:56 PM
FireHawx
Joined Oct 2011
Nice vid, i think this will be my next purchase. Wish i could get a kit from Motion, i will save $$ by getting the 3S version and adding my own power set up. Servos you use stock?
Old Yesterday, 09:48 PM
Joined Jun 2009
Flew my F22 tonight. It was my first EDF flight ever. I hadn't flown in over a month so I did a flight with my PZ T-28 to get back in the groove.
I did 2 flights about 2-3 mins each, looked cool and had a blast... after I got it on the ground and could relax that is My first 2 landings were ok, a slight bounce. My third was bad I let it come down to fast and did a huge bounce but I brought it home in one piece.
I felt like it was under powered though. I was flying around with about 75% power and needed 100% to gain altitude, a loop is pretty much out of the question without a WOT slight dive. On the first takeoff I was a little worried If I would have the power to get off the ground. Is this normal? Could there be something wrong with my motor? I think my stock PZ T-28 with 20C battery could beat this in a race.
Here is the battery I was using for both flights.
Turnigy 2200mAh 3S 25C
http://www.hobbyking.com/hobbyking/s...dProduct=14975
Old Today, 09:11 AM
Comin' in HOT!
tdford's Avatar
Joined Dec 2012
The 3s version is probably a dog . The F22 is also not a light EPS jet that some use to be. IMO, 4s is the way to go and will provide plenty of 's.
Yes, I'm running stock servos. I bought the 4s version and sold the power system right away to help pay for the fan upgrade. Like a $20 difference.... well worth it.
Old Today, 03:55 PM
Joined Jun 2009
I'm gonna upgrade to 4S. Might as well skip buying better 3S bats and just go all the way. Do you think I would be happy with getting MotionRC's 4S setup and throwing it in my F22 or should I upgrade a little more? What would be a good 4S motor upgrade that would fit with the 64mm fan?
Old Today, 05:08 PM
EDF rules... :)
AirX's Avatar
Joined Nov 1999
http://youtu.be/SkWcNjPezss
Nice video.
Eric B.
AirX is offline Find More Posts by AirX
For Sale 64mm f-22 raptor arf thundercracker Aircraft - Electric - Jets (FS/W) 16 Jan 02, 2014 03:52 PM
Discussion Advice for F-22 Camo Raptor 64mm 4CH RTF Ducted Fan RC Jet anthjames Foamies (Kits) 1 Jul 03, 2013 09:44 PM
Wanted 64mm F-22 joe1 Aircraft - Electric - Airplanes (FS/W) 0 Apr 28, 2013 02:03 PM
For Sale F-22 $ 60.00 64mm Shumate design converted to edf VIDEOPRO Aircraft - Electric - Jets (FS/W) 0 Jan 04, 2013 12:41 PM
Sold Starmax F-22 EPO 64mm EDF ARF, New version Joe 1320 Aircraft - Electric - Jets (FS/W) 1 Jul 16, 2012 11:21 AM
