Old Sep 10, 2013, 03:22 AM
Joined Sep 2013
Help!
Buy piano or music wire for pushrods from Malta
Hello to all,
I am new to this hobby and i am trying to get the best of it.
I am doing a scratchbuild and i need piano/music wire for pushrods.
I live in Malta and here all is more expansive and hard to get.
I was wondering if someone know a place from where i can buy some preferably local but if not somewhere with low shipping cost.
Size: 0.047"/1.2mm width by 36"/1m length
Example: http://www.3dxhobbies.com/music-wire...36-music-wire/
Regards,
Andrew
ziffa27 is offline Find More Posts by ziffa27
Old Sep 10, 2013, 09:10 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Sorry can't help on the piano wire, but what about alternative methods.
For a long(ish) push rod I use hard balsa strip, (often 1/4" sq), with sort wire ends. You may get away with a slightly softer wire for short rods such as the larger size paper clip.
It can depend on the expected load on the push rod.
Another method is the 'pull-pull', where you use a wire, (something like a fishing trace), connected between the servo, (double arm), and two control horns.
There are probably other methods that don't use piano wire, or the pre-threaded push rod for a quick-link.
Innovation is one of the mind stretchers for model builders.
Addition: Just thought there are also the 'plastic snakes', but they do require the end fittings.
eflightray is offline Find More Posts by eflightray
Old Sep 11, 2013, 04:16 AM
Joined Sep 2013
Thanks a lot for the idea and the feedback i really appricatated.
Old Sep 11, 2013, 08:45 AM
United States, TX, Leander
Joined Sep 2003
Some have used brazing or welding rod for push rods. It would be a good idea to look for some tube to put it in too.
Edwin
edwin1 is online now Find More Posts by edwin1
Old Sep 11, 2013, 12:51 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Another useful source of metal rods is bicycle wheel spokes. Look for the thinner ones for weight saving. You may even find some clevises will screw on the threaded end, or even use the 90deg bend with the 'knob' end at the horn or servo arm.
Old Sep 11, 2013, 01:35 PM
Joined Sep 2013
Edwin
Thanks for the feedback but i think they are a bit expensive and also a bit have.
Joined Sep 2013
That is a good idea, thanks so much.
Old Feb 15, 2014, 12:53 AM
Joined Oct 2009
Those little flags used to mark buried power lines or mark wireless dog fences are 1.6mm. Also Suspended ceiling wire is aluminum and about the same 1.6mm.
NL_Expatriate is offline Find More Posts by NL_Expatriate
