Old Feb 18, 2013, 03:15 AM
SONICX's Avatar
South Africa, GP, Krugersdorp
Joined Jul 2012
Build Log
SuperSloFly 28
Here is the build of the SuperSloFly 28 by Sloper Steve http://www.sdparkflyers.com/super.html
Not having 9mm EPP ,I have sandwiched two 6mm sheets for the three main parts with the 3mm cf rods inbetween.
This is a great looking plane and so far lots of fun to build.
This will be my first plane that actualy will fly and crash ,I hope.
Just need to get it finnished(time is always a problem)
Any way here is pics of my progress.
SONICX is offline Find More Posts by SONICX
Old Feb 19, 2013, 10:14 PM
AKA Don
bz1mcr's Avatar
Troy, MI USA
Joined Dec 2002
Interesting paint techniques.
The link in your post is not working for me.
bz1mcr is offline Find More Posts by bz1mcr
Old Feb 20, 2013, 01:20 AM
SONICX's Avatar
Joined Jul 2012
Here is "Parkjets.com" link with plans http://www.parkjets.com/superslo28/ and here is a link to "tallflyer's" build log
http://www.rcgroups.com/forums/showthread.php?t=959721
Old Feb 20, 2013, 02:27 AM
SONICX's Avatar
Joined Jul 2012
Here is some more progress.
Now done with the painting,not perfect,some overspray caused by spraying in light wind out side, but nevertheless it wil do for this build.
Time is a luxury around here and I want to maiden on the weekend.
Old Mar 05, 2013, 12:59 AM
SONICX's Avatar
Joined Jul 2012
Here is a little bit of progress.
All control surfaces hinged and 3 main parts clued together.
Now i can get a feel for what it is going to look like.
The air frame as is with out electronics and rods are 144g
Speed controller with motor and prop is 53g
I'll be using 9g servos but not yet sure what battery.
Motor is a Arrowind Black 1620kv I think with 8x4 prop
I'm not sure if i should go 2S or 3S
I'm aiming for a all up weight of 250g-260gwhich I hope is not
going to be to heavy.
Old Mar 08, 2013, 03:01 AM
SONICX's Avatar
Joined Jul 2012
here is some progress from last night.
Finnished the engine mounting and added cf strip at bottom.
Next will be to fit engine and horns ext.
Old Mar 08, 2013, 06:52 PM
Former Futaba employee
Joined Aug 2006
Great build log, keep up the good work.
keyman923 is offline Find More Posts by keyman923
Old Mar 11, 2013, 05:42 AM
SONICX's Avatar
Joined Jul 2012
Well I finnished the Build on the week end.
Final weight seems bit heavy at 366g
This is with 3S 800mha ,20A Ecs and 4x6g Blue Bird Servos.
Motor might be a tad weak,I have a bigger motor that I will use
if this one does not work.
Now I need to find out where the cg should be and try to fly it.
I'm still learning to fly so I'll just try to keep it in the air and land in one piece.
Old Mar 18, 2013, 02:55 AM
SONICX's Avatar
Joined Jul 2012
Did the maiden on Sunday but was not succesfull,the wind was to strong and flight lasted 3second.End result ,she will fly next time and a broken prop.
I'll try again on weekend.
Old Mar 18, 2013, 10:15 PM
AKA Don
bz1mcr's Avatar
Troy, MI USA
Joined Dec 2002
Linkto plans in post #1 is still not working.
Old Mar 19, 2013, 01:29 AM
SONICX's Avatar
Joined Jul 2012
Ok fixed it to another link that works at sdparkflyers in post #1
Old Mar 19, 2013, 08:35 PM
AKA Don
bz1mcr's Avatar
Troy, MI USA
Joined Dec 2002
That works great. Thanks.
Old Mar 19, 2013, 08:36 PM
AKA Don
bz1mcr's Avatar
Troy, MI USA
Joined Dec 2002
Now, that works great. Thanks.
EDIT, Sorry system glitched and did not show the first post until the second was posted.
Sold For sale: Plans for dumas 28" chris craft semi enclosed cruiser Tim B. Boats (FS/W) 2 Apr 05, 2013 11:11 PM
Found Parkzone T-28 Trojan ryanf58 Aircraft - Electric - Airplanes (FS/W) 1 Jan 04, 2013 01:13 PM
For Sale For sale set of KEDA 28 motors markymarkz Aircraft - Electric - Multirotor (FS/W) 5 Jan 02, 2013 08:29 PM
Wanted ASW 28-18 (3meter fuselage) Joe Casey Aircraft - Sailplanes (FS/W) 1 Jan 02, 2013 05:25 PM
Wanted Arc 28-47-1 / 28-48-1 / 28-58-1 or a Typhoon 2w20 jgalexander Aircraft - Electric - Power Systems (FS/W) 4 Nov 26, 2012 04:44 PM
