Old Jan 31, 2013, 04:52 PM
United States, NY, Schenectady
Joined Sep 2009
Question
Pushing Motor to Limit - Is esc likely to also Fail
I am flying the Parkzone P-47 with stock PZ 15 motor, 4s2200, 9x7.5E prop and 45 amp esc.
Max amps:37 Watts:580 watts
Being winter there have been no heat issues. Also, the specs on that motor are a bit murky. The similair E-flite Power 15 is rated at 575 watts and 4 cell usage.
I don't mind the risk of damaging this motor as long as the control surfaces work, allowing a dead stick landing. So, if I throw a magnet or experience life ending damage to this motor will the esc survive for a dead stick landing?
Buster1000 is offline Find More Posts by Buster1000
Old Feb 01, 2013, 04:30 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
In theory, probably yes.
But that's a bit like asking, if I buy a model plane will I crash it.
There could be a few, 'it depends'. The BEC built into an ESC is sort of independent of the motor power side, but if the power side went up in flames then.......
On 4s, I assume the BEC is a switching one designed for 4s, (many 2s-3s ESC's used a linear BEC that is not suitable for 4s), then I should be fine.
Whatever is used, in whatever model, some cooling air over the ESC, (and motor/battery), is always a good thing.
eflightray is offline Find More Posts by eflightray
Old Feb 01, 2013, 08:36 PM
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia / UK visits
Joined Jan 2010
If motor gives out - as long as it doesn't short the power ... the ESC should be ok. But trouble is usually the motor giving out does short and ESC cannot handle that.
As other guy says - BEC is separate from the motor power - but still on same board .. so burning out power side often hits BEC as well.
Now I'm going to type something that is controversial ... I use many ESC's with 4S and I have never had any problem. It's only recently after so many keep posting about BEC and 4S that I started to really look closely at the ESC etc.
I run models with 4 .. 5 servos (mostly 9gr) 3S ... 4S ... with inbuilt BEC ... any control issues ? No.
But my 5S - I do run separate BEC without question.
Nigel
solentlife is offline Find More Posts by solentlife
Sold Like New Rimfire 28-22-1380kv brushless motor and an Electrifly SS-8 ESC combo mechengineer03 Aircraft - Electric - Power Systems (FS/W) 0 Jan 12, 2013 08:08 PM
Question Bad Motor or ESC? Motor Fails to Start Sometimes Bukkene Bruse Power Systems 1 Mar 10, 2010 11:22 AM
For Sale Ion-X Motor & Master 77 ESC also have Master 48 ESC jdr1973 Aircraft - Electric - Helis (FS/W) 0 Aug 13, 2007 10:23 PM
Motor Max DF400, Anyone pushed this thing over the limit yet? Ender Power Systems 0 Apr 11, 2005 10:04 PM
EBAY:FS cobalt 400 motor and 30A ESC Also speed 400 motors and wingo props JIMinKENTUCKY Aircraft - Electric - Airplanes (FS/W) 1 Mar 30, 2004 06:51 PM
