Old Nov 26, 2012, 09:59 PM
xrx1113's Avatar
United States, FL, Lehigh Acres
Joined Aug 2011
Help!
Pictures included ailerons seperating from foam
Well i got my throws a bit higher with the momentary launch switch and more energy into the through but then I started to lose trim and it turns out I broke it. The ailerons are coming away from the foam. The skin is intact but pealed away from the foam on the inside of the wing. Anyone have a quick fix for this?
xrx1113 is online now Find More Posts by xrx1113
Old Nov 26, 2012, 10:04 PM
1900 Driver's Avatar
Denver CO
Joined Mar 2009
Yeah. Soak thin foam safe ca in or a better fix is to use some laminating resin. My vandal wing is pretty much all ca along the aileron hinge line. It slowly peeled away and has be better ever since!
Brandon
1900 Driver is offline Find More Posts by 1900 Driver
Old Nov 26, 2012, 10:17 PM
G_T
Joined Apr 2009
If one is having this issue, then I'd recommend looking up Oleg's or Mark Drela's notes on facing flaperons. The fabric will help tie the skins together and aid in preventing this.
Or you can do what I've done which is inset a 1/8" thick strip of vertical grain balsa for an inch each side of the control connection. This is the highest stress area and where delamination typically occurs first on a top drive installation.
Gerald
G_T is offline Find More Posts by G_T
Help! First flight tore off an aileron-foam. Sculptor Beginner Training Area (Aircraft-Electric) 3 Apr 02, 2012 07:25 AM
Help! First flight tor off an aileron-foam Sculptor 3D Foamies 5 Apr 01, 2012 06:38 PM
Discussion motor plate seperate from its can bigtruck169 Electric Plane Talk 2 Mar 10, 2012 07:44 PM
