Old Mar 05, 2012, 06:24 PM
GOOBERSEPTEMBER's Avatar
United States, PA, Monroeville
Joined Aug 2007
Help!
Hacker a10 9l mounting help
I want to use the a10 9l into an Eflite Cessna 150
http://www.e-fliterc.com/Products/De...ProdID=EFL5050
I don't see how to mount it??
GOOBERSEPTEMBER is offline Find More Posts by GOOBERSEPTEMBER
Old Mar 05, 2012, 06:28 PM
Joined Aug 2007
Stock motor mounted. (not my pic)
Old Mar 06, 2012, 01:18 PM
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Mounting Hacker 9L motor
The hacker 9L comes with two different mounts. One is fiberglass, and is used to tape the motor onto foam planes, such as depron. (yellow in the photo)
It also comes with a alum. mount that has four screw lugs that can be used to bolt the motor to a firewall, such as seen in your photo.
A small hole will need to be drilled into the plywood to allow the motor shaft to pass thru, although it is probably already there for the eflight 250 motor.
I've attached a photo from the Hacker website, but its small and not easy to see, although you can see the metal mount (black) in the photo.
you might have to use some additional ply or washers to get the correct spacing for the plane cowl.
aerolite
aerolite is online now Find More Posts by aerolite
Old Mar 06, 2012, 03:57 PM
Joined Aug 2007
Those came with my motor. ???
http://www.microcopters.de/photos/101/dsc-1775_1000.jpg
I can't seem to figure out how to mount what I have like the above. Lol
Old Mar 06, 2012, 04:08 PM
Joined Aug 2007
The prop adapter fits on the shaft not the backside. Am I able to flip the shaft so it sticks out the rear??
Here is what I'm talking about.
Old Mar 06, 2012, 07:47 PM
Joined Aug 2007
Well, not sure if this is the right, but after contacting another member, I've come to the conclusion that all I have to do is flip flop the shaft and instead of the "c" clip I'll just use a 2mm collar.
I just did this, minus the collar I have to pick up at my lhs and all seems to be exactly what I needed.
Old Mar 06, 2012, 07:53 PM
Joined Aug 2007
Plenty of room for a collar.
Discussion Hacker a10-9l Question FASTALJR Indoor Pattern/F3P 26 Mar 13, 2012 07:15 PM
Sold 2 Hacker A10-9L Azarr Aircraft - Electric - Power Systems (FS/W) 1 Jan 27, 2012 02:33 PM
Wanted Metal Mount for Hacker A10-9L geekrawker Aircraft - Electric - Power Systems (FS/W) 0 Jan 26, 2012 12:33 AM
Sold Hacker A10-9L with X-7 esc and Thunder power 2s 480mah lammbn Aircraft - Electric - Power Systems (FS/W) 5 Jan 12, 2012 09:56 AM
Discussion Hacker A10-9l Motor ? xtremeRCpilot Indoor Pattern/F3P 6 Jan 12, 2012 09:18 AM
