Old Nov 26, 2011, 08:10 AM
Nashville TN
Joined Jan 2007
How do you turn OFF a switch on a DX-7 radio?
Hi to all,
I have a DX-7 and have mixed the aileron with the AUX2 because I am using two servos for the ailerons and need the end point adjustment for each.......I can get that to work , but I want to turn OFF the toggle switch to the AUX 2 in the top of the radio for saftey reasons.
So my question is how do I turn the toggle off....but still have the mix on at all times? I'm sure that this is simple.......but can't figure it out.
Thanks and happy flying!!
Eng30
Nashville , TN
eng30 is offline Find More Posts by eng30
Old Nov 26, 2011, 08:21 AM
59 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
SYSTEM MODE, INPUT SELECT, AUX2, INH
It affects the action of the switch, not the mix.
See Input Select in the manual (page 38 in my version).
Daedalus66 is online now Find More Posts by Daedalus66
Old Nov 26, 2011, 08:31 AM
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Wouldn't it be better to use Flaperon mode with dual ailerons?
You can still adjust endpoints, plus you get differential mode.
And if you want you can get flaps. (By default they are on, so you have to go into the flap system menu and set everything to zero to disable them)
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old Nov 26, 2011, 08:35 AM
Nashville TN
Joined Jan 2007
I will go and try both soulutions right now.....
Thanks !!!
Old Nov 26, 2011, 09:22 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Pat MacKenzie
I agree it's a better solution. I was just answering the direct question, assuming there was some reason for not using the built-in mix.
This is one of those cases where before giving the answer you need to make sure the question is the right one.
Discussion How do you turn off the 2.4 Ghz band? Voguna FPV Talk 4 May 05, 2011 02:11 PM
Discussion How do you turn off the thumbnail photos IBWALT Thermal 25 Apr 22, 2011 06:32 PM
Discussion How do I remove an on/off switch from ESC drumbum Power Systems 10 Apr 22, 2011 10:28 AM
Question How do I set all dual rates on 1 switch with DX-7? garyinpa Beginner Training Area (Fuel) 3 Jul 03, 2009 12:29 PM
What to do, before you turn on your radio and take off CheckList Patrick Plawner Electric Plane Talk 31 Feb 11, 2005 04:42 PM
