Old Mar 10, 2011, 10:07 PM
Electric baptism 1975
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
Help!
ESC settings for Wicked 5400
At last this made it out the box & into an Alfa A4. Doing shop testing as I assemble.
Plan is for 3s TP 45C either 1750 or 2200. ESC is CC Phoenix 25. I initially had problems reading the ESC and it turned out to be on normal timing which didn't allow the fan to spool up. On Low timing & PMW 12 Khz on an 850mah partly charged test battery, which only has a red JST connector I get 22.8 amps.
Would PMW 8 be a better setting??
NB I will post on CC as well
DavidN is offline Find More Posts by DavidN
Old Mar 10, 2011, 10:22 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
The Pentium ESCs I sell are 8kHz PWM, and I set them to "low" timing, and "normal" startup. You will want to start with similar on the Castle ESC. Are you running the 3 blade alfa rotor or the 5 blade rotor?
The Don is online now Find More Posts by The Don
Old Mar 10, 2011, 11:32 PM
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
Thanks for the quick reply Don. I am using the 3 blade fan. I will try 8 PWM
Sold Wicked 5400 esc and fan ready to go. xjwrench1969 Aircraft - Electric - Power Systems (FS/W) 7 Oct 26, 2010 06:27 PM
For Sale Brand new dynamically balanced Wicked 5400 in 60 mm fan. The Don Aircraft - Electric - Jets (FS/W) 0 Sep 16, 2010 12:10 AM
Data ESC settings you use for you Wicked EDF motors The Don Don's RC 2 Mar 26, 2010 09:52 PM
For Sale wicked extreme 5400 kv,pentium esc,and fan 65$ kremecheze Aircraft - Electric - Power Systems (FS/W) 0 Sep 23, 2009 02:34 PM
Sold Dons Wicked 5400 and pentium 40 ESC neilo Aircraft - Electric - Jets (FS/W) 5 Sep 26, 2008 05:06 PM
