Old Dec 27, 2010, 02:53 AM
BRISVEGAS BABY
Joined Mar 2010
Patch antenna's and the Ground plane
Hi all
Does anyone know what the optimal distance is for me to mount my 900mhz patch from the ground. I have heard so far various conflicting reports including 1/2 wavelength above the ground too full wavelength. Also at such close proximity to the ground what is the optimal angle ? I see alot of people mounting their patches at about 45d egrees so as not to "waste" any of the receiving range by including the ground in the angle, but other reports indicate the the ground actualy reflects the signal and performance is best at angles at around 75degrees.
Would love some clarification on these issues.
nathan089 is offline Find More Posts by nathan089
Old Dec 27, 2010, 07:08 AM
Joined Dec 2010
anyone
wickedvid is offline Find More Posts by wickedvid
Old Dec 27, 2010, 07:45 AM
The Fixer
Martin Y's Avatar
Canada, ON
Joined Jan 2009
You have to try it out as not all areas will perform the same way.
Martin Y is online now Find More Posts by Martin Y
Old Dec 27, 2010, 07:47 AM
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
I have a dual patch setup - they are mounted at a 45 to each other - and point about 35 to 45 in the sky. The center of the patches are less than 12" off of the ground.
I'm not sure if this is ideal - but it works for me.
Blue Chip is offline Find More Posts by Blue Chip
Old Dec 27, 2010, 07:49 AM
Joined Aug 2009
I have no A/V drop outs and excellent Picture +- 40cm from the ground, try different heights and see what the best for you is
Moosthegoose is offline Find More Posts by Moosthegoose
Old Dec 27, 2010, 07:54 AM
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
I have about 8' of cable to get the patches away from everything and about 8 feet or so of feed cable to the goggles (or TV).
I built a wood bracket that velcro's to the tripod - the parches attach at 40 degrees - again - by velcro. The dual recievers are mounted on the back. The bracket that the patches mount to is hinged - that way I can change the altitude which they are pointing. The only thing that I would consider changing is adapting the bracket so I can change the altitude of each patch independently of each other.
Old Dec 27, 2010, 08:08 AM
BRISVEGAS BABY
Joined Mar 2010
ok so the general idea im getting is trial an error is the way to go. But i am seeing that most of everyone has there patch pretty close to the ground... has anyone had better results with thier patch on an tripod (4-6 feet) from the ground.
also any opinions on the angle from the ground. I do not mind if it is personal expereince or a scientific model.
Cheers
Old Dec 27, 2010, 08:24 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Patches are ground plane dependant. I mount mine between 4 and 6" off the ground for best results.
IBCrazy is offline Find More Posts by IBCrazy
Old Dec 27, 2010, 08:38 AM
BRISVEGAS BABY
Joined Mar 2010
thankyou, what is your opinion regarding the angle of the patch from the ground. (if it matters i do everything from fast flying (100-150km/h) close to the gound to high altitude slow flying)
Old Dec 27, 2010, 08:39 AM
BRISVEGAS BABY
Joined Mar 2010
also regarding the measurements are the from the center of the patch or from the bottom.
thanks again
Old Dec 27, 2010, 08:55 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
4-6" from the bottom of the patch and angled 30 degrees seems optimal.
Old Dec 27, 2010, 09:18 AM
BRISVEGAS BABY
Joined Mar 2010
thanks everyone for your help.... this info fits well with my plans for my new ground station. thanks again.
cheers
Old Feb 19, 2011, 03:52 AM
VaZ
TheFlyer_PT
VaZ's Avatar
Portugal
Joined Feb 2011
IBCrazy, it's true that yagis do not have this kind of issues?
VaZ is offline Find More Posts by VaZ
New Product New 2.4 Ghz Ground Station with integrated Vrx and Patch antenna nakelp86 FPV Talk 409 Apr 02, 2013 11:19 AM
Mini-HowTo DIY Ground Plane omni directional RX antenna IBCrazy FPV Talk 60 Nov 19, 2012 06:11 AM
Wanted Need a 1.2GHz patch antenna and an antenna tracker ChrisS Aircraft - General - Miscellaneous (FS/W) 1 Jun 17, 2011 07:07 AM
Discussion 14dbi 2.4GHz patch antenna with EagleEyes ground station randy57 FPV Talk 1 Mar 03, 2010 05:08 PM
Question What Patch Antenna for Video Ground Station ? Tatty Aerial Photography 15 Mar 21, 2009 09:55 AM
