Old Jul 13, 2011, 07:18 PM
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Originally Posted by Dave Grife View Post
Hey Guys,
I flew mine at Mid-America Electric Flies this past weekend.
Here's A few pictures from Greg Cardillo's Skillful lens.
Too bad my landing wasn't so skill-full
(holding lots of rudder in photo # 8)
-DG
P.S. TJ 80 1509 2Y with Tam Struts.
My right gear needs a new spring.... ....didn't fully retract.
Nose gear took 15 minutes to fix after landing badly.
Looking forward to more flights this weekend.
This plane is really tough.
Good flying....don't feel bad stressing the springs.
I got bunch of them....
Even I goes through few set of springs now and than. But my wings and retract are safe.
Tamjets is offline Find More Posts by Tamjets
Old Jul 13, 2011, 07:33 PM
Jetnfast's Avatar
United States, MO, Warrensburg
Joined Feb 2008
The other advantage to crow and the extra drag created which acts like a speed brake means you will carry a higher power setting on those flat approaches which is nice in case you need to go around and is all the more important for the turbine powered jets.
Jetnfast is offline Find More Posts by Jetnfast
Old Jul 13, 2011, 11:51 PM
Fly Fast!
dbgood's Avatar
scotia ,NY
Joined Jul 2008
Ok i cant find a way to add crow to mix it in with flaps and elevator,on my DX8
right now im using for
Mid flaps 11mm
elevator 1mm down,
Full flaps 25mm
2mm down elevator.
Or should i just increase the flaps and elevator settings?
I only used mid flaps to land with no power and it took me forever to get it down,many tries just keeps gliding with no power on,my Habu 32 seems faster landing, then my Pulse 60 when at full bore with the big old scorpion in it>YIKES
dbgood is offline Find More Posts by dbgood
Old Jul 13, 2011, 11:59 PM
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Mid flaps 11mm
elevator 1mm down,
Full flaps 25mm
2mm down elevator.
Is there Flight Mode on DX-8?
If do..set up Flight too.
Assign the Flight Mode to flap switch and had the trim in Flight mode condition.
So each Flight Mode you can trim independing.
Old Jul 14, 2011, 01:01 AM
Fly Fast!
dbgood's Avatar
scotia ,NY
Joined Jul 2008
Yea Tam there is a flight mode -1,2,3,i use that on my Trex 700 e heli
I have to figure out a way so when i hit the flap switch,then crow is added
Thanks Dan
Old Jul 14, 2011, 02:53 AM
dale4040's Avatar
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Jan 2010
As far as I can see the flight mode switch on the DX8 only apllies to helis. I would love to be able to use this for my 32 and can't see why the DX8 won't allow it.
dale4040 is offline Find More Posts by dale4040
Old Jul 14, 2011, 04:14 AM
Denmark, Nordjylland, Gistrup
Joined Aug 2005
I think Tclaridge is using flightmodes on a DX8. He is not using the flapswitch. And I even think he is using crow when flying without flaps. He has assigned the flightmodeswitch to the flapmix. Maybe you could try: 1 low rates no flap, 2 high rates mid flap and crow, 3 high rates full flap and crow.
flemsus is offline Find More Posts by flemsus
Old Jul 14, 2011, 08:05 AM
Fly Fast!
dbgood's Avatar
scotia ,NY
Joined Jul 2008
So what are you guys using for flaps mid -and high ?
11 mm for mid
and
25 -mm for landing?
Or are guys putting in more to slow it down,
Old Jul 14, 2011, 09:59 AM
Its a Condition not Addiction
lashmett75's Avatar
United States, CA, Sunnyvale
Joined Jul 2008
11 mm for mid
and
25 -mm for landing?
Here are my settings posted here months ago...
crow and flaps setup...here are the measurements
mid / take off
elevator..4mm down
flaps...30 degrees down
crow...4mm up
landing
elevator...6mm down
flaps...45 degrees down
crow...8mm up
lashmett75 is offline Find More Posts by lashmett75
Old Jul 14, 2011, 10:07 AM
North Central Positronics
badbill's Avatar
USA, GA, Centerville
Joined Dec 2002
Put two more flights on my Habu 32 yesterday, for a total of 3. With the throws dialed in I am very comfortable with it now. I have always thought it seemed faster than what people said on here, and now I know why- I'm attaching my data log which shows 1991 watts, 84 amps. Stock motor / fan with Ice 100 esc. The Align 6s 5200 lipos are awesome, they really deliver. Running a 1100 A123 rx pack, and only using 40mah per flight.
Check out the Castle data log attached-
Bill Davenport
AMA 28141
badbill is offline Find More Posts by badbill
Old Jul 14, 2011, 10:12 AM
737DRIVER
tvessie's Avatar
United States, CA, Woodbridge
Joined Mar 2008
Hello my friend. I have the same radio you do, and I use that flight mode switch, now don't everyone jump on me cause this is slightly off topic of Habu 32 talk (but I do have one and use this radio on it and I LUV the Habu COME ON 90MM VERSION!!!), on my giant gasser and use the flight mode switch in POS 0 for full throw on every flight control surface, POS 1 for 1/2 throw on all flight control surfaces, and POS 2 for 1/2 throw on all flight control surfaces with a mix of rudder to aileron for coodinated turns. That way you don't have to move 3 switches for each flight control surface. Berry Simple, Berry easy pessy! I use the same switch and do the same with it on the Habu 32
tvessie is offline Find More Posts by tvessie
Old Jul 14, 2011, 10:30 AM
More jets than a carburetor
skydve76's Avatar
United States, NE, Omaha
Joined Sep 2008
Do you guys think there is room for two 6s 5000s 30C in there? A 12s setup would be cool....
skydve76 is offline Find More Posts by skydve76
Old Jul 14, 2011, 11:23 AM
dale4040's Avatar
Joined Jan 2010
Sorry for the detour on the Habu discussion but found the F-mode secret--you have to enable it in dr/expo. As you were.
Old Jul 14, 2011, 11:36 AM
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
How you go to balance it and that is super heavy.
I run 10s 3600mAh is already 8.1 lbs and I kept it very light.
Old Jul 14, 2011, 11:47 AM
ZACATTACK's Avatar
Joined May 2011
Tam.Almost done..Got all the goodies. Great Job Tam. I guess I remove the wooden battery tray for the 8S set-up??
ZACATTACK is offline Find More Posts by ZACATTACK
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
