Old Apr 12, 2010, 06:42 AM
Jiffy's Avatar
Joined Nov 2005
Extra300 Mid-wing 50cc - Help Please
Hi I'm buying a Extra300 Mid-wing 50cc, and I need to know what Hi Tec servos to buy, could anybody please help and send me the model number, I know they need to be metal, but need more info please.
http://www.egaircraft.com/products.php?sort=14&id=26
Many thanks for your help
Jiffy
Jiffy is offline Find More Posts by Jiffy
Old Apr 12, 2010, 08:04 AM
bryant330l's Avatar
Salem, IN
Joined Feb 2004
Hi Jiffy,
There are a couple of different models that will work, depending on how much you wanted to spend. You probably will want a 7955 on the rudder. You could put a 7950 on it but the 7955 would have enough power for it. The throttle can use any standard torque servo, but metal gears might stand up to the vibrations better with the gas engine. For the other surfaces, you can use 7985s and they will work fine, or you can put 7955s all around and have more than enough torque. I would stay away from the 5645s as they are slow and do not center very well. I have these setups on a couple of my 50cc planes and they perform great.
I saw the EG 50cc Extra at Toledo and it is a great looking plane. I think you will like it.
bryant330l is offline Find More Posts by bryant330l
Site Sponsor
Old Apr 12, 2010, 08:31 AM
Test your skills....fly IMAC!!
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
Jiffy
Jiffy,
I would go with HS-7955's on all control surfaces in this plane. They have excellent torque, great centering, and can be run on 7.4v of power.
Tim
sun.flyer is offline Find More Posts by sun.flyer
Old Apr 12, 2010, 01:36 PM
Jiffy's Avatar
Joined Nov 2005
could you please tell me, whats better the Savox 1256s all over it and a 1258 on rudder or the hi-tec servos?
thanks
Old Apr 12, 2010, 03:10 PM
Jiffy's Avatar
Joined Nov 2005
hi guys are these the servos you suggest for the model?
http://images.google.co.uk/imgres?im...26tbs%3Disch:1
and a standard servo for the throttle?
Old Apr 12, 2010, 04:03 PM
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
Jiffy,
Yes, those are the servos. Excellent servos as stated above. I'm not sure about the other servos you have listed. I've never run them in any of my giant scale airplanes.
Tim
Old Apr 12, 2010, 04:43 PM
Jiffy's Avatar
Joined Nov 2005
thanks very much for all your help guys, I will order these hi tecs.
thanks
Jiffy
Old Apr 12, 2010, 04:45 PM
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
thanks
Jiffy
Any time Jiffy!!
Tim
For Sale Sig sundancer 50cc gas 72" wing fpe 3.2 johnsheri Aircraft - Fuel - Airplanes (FS/W) 4 Apr 28, 2012 06:39 AM
Help! Please help program 9c for a three servo wing maxadventure Radios 1 Mar 26, 2010 02:56 AM
Question Motor Search for Mid-mounted EPP Wing/Prop Jet gtslope Foamies (Scratchbuilt) 0 Mar 05, 2010 12:20 AM
Wanted mini ultra stick wing Please Please Help Flazo Aircraft - Electric - Airplanes (FS/W) 6 Jan 02, 2010 09:30 PM
Help! HELP!!!!!! H9 Cap 232g 27% 50cc PLEASE!!! AussieJarred Australia 10 Mar 30, 2009 01:30 AM
