Old Dec 03, 2005, 12:07 PM
duhaas88 is offline
Find More Posts by duhaas88
Las Vegas
Joined Jun 2004
PCB layout for Mr.RC-Cam's Servo tester
I was wondering if anyone is good at PCB layout that can translate this to a PCB layout for me? It is Mr. Rc-Cam's servo tester(I hope he doesn't mind), I wanted to make it nice and clean and etch my own board, but don't know anything about Eagle cad to do so. Can someone that is very proficient with this whip up the PCB layout??
I'd appreciate any help
duhaas88 is offline Find More Posts by duhaas88
Old Dec 03, 2005, 12:52 PM
kfong is offline
Find More Posts by kfong
Sterling Heights, Michigan, United States
Joined Nov 2003
UPDATE, the schematic is correct, my bad. The board works now thanks to Rc-cam. Thanks Thomas.
OLD POST:
I've already made a board, but it didn't work right. For some reason his schematic seems to be wrong or perhaps the software. The pot function does not seem to work. Everything else is ok. I see the rc time constant change on the input with changes to the pot, but the pic doesn't respond with servo commands.
I have a few more boards left if you are interested in one, but I would look into way the schematic or software is wrong first.
Kin
http://www.embeddedtronics.com/
kfong is offline Find More Posts by kfong
Old Dec 03, 2005, 01:03 PM
mrbaseballny is offline
Find More Posts by mrbaseballny
mrbaseballny's Avatar
Joined Sep 2004
I guess we need Mr. RC-Cam to chime in here and give us his wisdom do you have the file that you could print out of the pcb layout??
mrbaseballny is offline Find More Posts by mrbaseballny
Old Dec 03, 2005, 01:53 PM
Malc C is offline
Find More Posts by Malc C
UK
Joined Oct 2003
I'm no expert, but it could be either the hardware or software that's the problem as Kin has stated. A PIC should be able to generate the 1 - 2ms pulses on a 20ms time frame without any external timing circuitry (assuming thats what the two capacitors and resistor is). Hopefully Mr RC-Cam will shed some light with a full CCt discription and help you out.
Malc C is offline Find More Posts by Malc C
Old Dec 03, 2005, 02:47 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
12C508 PIC chips don't have an A/D converter. Looking at the schematic (I don't know where the code is), I would assume that the designer intends to set GP5 to an output charge the capacitor by setting the output high for 'x' length of time, and then time the discharge by setting GP5 to an input and using the timer to determine how long it takes to for input to become TTL low. This time will vary with the resistance of the pot. This is a very simple trick that is used quite often when you don't want to go to a higher end PIC.
JimDrew is offline Find More Posts by JimDrew
Old Dec 03, 2005, 03:18 PM
Malc C is offline
UK
Joined Oct 2003
Jim, thanks for informing us why there are additional components. I would of thought that it would be better to of used a 12F675 as that has A/D functionality - still an 8 pin package, and not what I would really call "high end" of the PICs available. You could then use a simple 10K pot wired as a divider could be used to adjust the servo position.
Old Dec 03, 2005, 07:25 PM
duhaas88 is offline
Las Vegas
Joined Jun 2004
I mailed Mr. RC-CAM a PIC12C508 for programming. I assume that your problem must be in the hardware then. If he shows that it works on his website then I wonder what you did wrong? or maybe something was changed by Mr.RC-CAM.
Hmm, I hope he chimes in soon
Old Dec 03, 2005, 09:11 PM
Mr.RC-CAM is offline
Find More Posts by Mr.RC-CAM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
Sorry for the problems. Hopefully I can help.
The PIC12C508 does not have a A/D. The RC time constant comprised of R1+R2/C1 is the solution. Several times a second the PIC charges up the CAP, then discharges it through the variable POT. It carefully measures the discharge time, which will change depending on the POT resistance. This effectively emulates a A/D function and is decently accurate.
The circuit is not fussy. It has been built by MANY hobbyists and no problems have been reported. The C1 cap should be a 2% part (or hand picked) to keep things honest. If the circuit does not work then my first guess (assuming it was wired correctly) would be that the OSCAL value was over-written during programming. If the PIC was obtained from me then we can cross this off the list.
Even if the cap and POT were horribly messed up, the switch selectable "Servo Center" feature should still work. If it doesn't, then the PIC is toast or wiring errors are in the way.
Mr.RC-CAM is offline Find More Posts by Mr.RC-CAM
Old Dec 03, 2005, 10:51 PM
duhaas88 is offline
Las Vegas
Joined Jun 2004
Kin
Can you post the pcb layout that you used so I can etch one??
Old Dec 04, 2005, 01:59 AM
westfw is offline
Find More Posts by westfw
westfw's Avatar
Joined Nov 2004
The schematic has three components that are very annoying from a PCB layout
perspective: the pot and the two switches. These come in SO many different
packages that the would-be PCB designer has to either know/guess exactly which parts
you're planning on using, or put standard pads on the board for connecting to off-board
parts (which is nice and general but just SO inelegant :-)
westfw is offline Find More Posts by westfw
Old Dec 04, 2005, 04:36 AM
westfw is offline
westfw's Avatar
Joined Nov 2004
Ask and you shall receive. 40x40mm, rather relaxed in its design rules. I added
the 2940 LDO regulator in case someone needs it.
I didn't see anything fishy with the schematic while in the process of
transcribing it, BTW. I can't tell whether the schematic matches the
firmware, of course, and this PCB is NOT tested.
And the Eagle .sch and .brd files, with a PDF that might work as layout.
rccam-servotest.zip
Old Dec 04, 2005, 09:27 AM
duhaas88 is offline
Las Vegas
Joined Jun 2004
Westfw,
Thanks for the PCB layout. I am going to give it a test tonight. I have all the parts except the PIC from MR.RC-CAM. So I'll populate everything but that. I'm sure that others will appreciate you doing this as well
Old Dec 04, 2005, 10:09 AM
kfong is offline
Joined Nov 2003
Hmm, I'll check the OSCAL, Servo center works when button is pressed, even the cycle function. I can see the time constant changing as it goes into the input pin. I had programmed the chip myself, so I will try programming it again when I get the chance.
Here is a picture of the board, only did a small run.
Kin
Old Dec 04, 2005, 12:59 PM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
That is a nice looking board. I can see the servo centering push switch, and the connector for the pot. Do you support the cycle switch? {Don't readily see it in there}.
If you want, you can mail the assembled board to me (along with the pot you will be using) and I will check it out to see what is going on. All I ask is that you include enough stamps to cover the return postage.
BTW, what fab house is "EW"?
Old Dec 04, 2005, 01:46 PM
kfong is offline
Joined Nov 2003
Thanks, Imagineering is what this board was from and even then I think they farm some of them out, but most boards houses these days do very similar work.
Yes the cycle switch is there, but since I don't intend to use it. It wasn't installed. I tested it by just shorting out the connector and it works.
Sure I can send it to you, just pm me your address. I'll send you a blank board for your troubles.
Kin
G-Smart Mini3 & Mr.RC-CAM switch underexposed? max z Aerial Photography 4 May 15, 2003 04:07 PM
Mr. RC-CAM + Mustek Mini 3 - Superb Ironsides Aerial Photography 7 Feb 17, 2003 11:29 PM
MR RC-Cam Cam-man chip for sale TJSlayer Aircraft - Electric - Airplanes (FS/W) 2 Feb 04, 2003 05:54 PM
Mr. RC-Cam Aiptek Mod jeff2215 Aerial Photography 0 Jan 01, 2003 04:46 PM
Wanted to buy, Aiptek 1.3 with Mr rc-cam mod snowman610620 Aircraft - Electric - Airplanes (FS/W) 1 Dec 27, 2002 09:54 PM
