Old Jan 21, 2015, 08:06 AM
mace04 is offline
Find More Posts by mace04
Joined Jan 2015
Power and trust to weight ratio for F-15
Hi,
I am sure this have been asked many times before however me looking at the threads I cannot get a straight answer or at least make my mind up if my thought are correct. So bare with me
I am in the process of building a depron (6mm) F-15 based on Shumate's design. I would like to install two 50mm EDF units but based on what I can get in the market, the weight will increase to around 35oz.
Am I right to believe that if I have a thrust to weight ration of 1:1 this will be sufficient to make the plane to fly comfortably without struggling? I have found a apir of EDFs in Hobbyking(Hobbyking 50mm Alloy EDF V2 4200kv) that will give a max thrust of 550g that I believe that is more than sufficient. The power of each unit is around 330W each which is more than enough to go over the usual threshold of 100W/lb.
I would greatly appreciate any thoughts on this
Michael
mace04 is offline Find More Posts by mace04
Old Jan 21, 2015, 10:31 AM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
A 1 to 1 is always nice but not needed. many jets can fly with only 30% thrust and 50% and up will fly well. A lot will depend on other aspects of the design as to how well the plane flys. like airfoil type and wing loading.. Thrust to weight is not a real good way to est how a plane flys. it just means it will be fast or slow. So for you weight may be a bigger factor with wing loading not thrust
turbonut is online now Find More Posts by turbonut
Old Jan 22, 2015, 10:02 AM
mace04 is offline
Joined Jan 2015
Thanks turbonut.
Based on the plans I am basing my construction the wing loading is 9.2 oz/sq ft for an AUW of around 16oz. I would assume this changes if I double the weight of the plane?
My main concern is doubling the weight of the plane in order to accommodate for 2 EDF units and the power needed on the back of that.
Old Jan 22, 2015, 12:35 PM
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
At 9.2 it will be pretty much a floater..at 20 oz it will be more jet like but will fly well
Question Power to weight ratio AELLC Power Systems 13 Apr 20, 2014 11:26 PM
Discussion Yellow aircraft F-15 kit vs Avonds F-15 kit weight nighthawk117 Large EDF Jets 23 Mar 27, 2014 09:00 AM
Discussion Rule of Thumb for Power to Weight Ratio darkmask Foamies (Kits) 2 Jun 12, 2006 01:54 PM
Best power to weight ratio for a smaller DF 66tbird Electric Ducted Fan Jet Talk 0 Mar 16, 2005 11:32 AM
