Old Feb 20, 2014, 04:39 PM
T.J.W is offline
Find More Posts by T.J.W
Joined Aug 2013
I now refuse to use spectrum kit as a short while after getting my parkzone Radian with DX5e, it lost connection and just flew straight and level and landed in a field about 50m away. a few months later, same thing again but i managed to get control back before it did too much. this happened two more times before it eventually got more serious. i had just looped it and it lost conection and to make things worse, it found a thermal and dissappeared off across the airfield (my local gliding club) before crashing into a hangar 3k away. since then i havent used spectrum gear and never will again.
just my 2p.
Tim
T.J.W is offline Find More Posts by T.J.W
Old Feb 20, 2014, 04:59 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
just my 2p.
Tim
Me too! I gave mine away. I would not accept money for it. As I've stated before, far too many threads reporting something along the lines of "Another Spektrum Failure".
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Feb 20, 2014, 05:26 PM
rrg is offline
rrg
Find More Posts by rrg
rrg
rrg's Avatar
USA, KY, Edgewood
Joined Dec 2007
5 years with Spectrum and no problem here. DX6, 7 and 8.......
rrg is offline Find More Posts by rrg
Old Feb 22, 2014, 05:00 PM
Parkflyer81 is offline
Find More Posts by Parkflyer81
N00b Sloper Addict
Parkflyer81's Avatar
Australia, TAS, Brighton
Joined Dec 2005
I dont think its spekturms problem only. Anything on DSM protocol has an issue from my experience. Orange, i think lemon are DSM too. Would expect the same from all of them.
But thats my experience, and opinion
Parkflyer81 is offline Find More Posts by Parkflyer81
Old Mar 03, 2014, 03:54 PM
rcflyertim is offline
Find More Posts by rcflyertim
Va
Joined Sep 2005
I am certainly not a Electrical Engineer nor do I profess to be an expert on the 2.4 GHz Radio Control equipment, but I have had good success with my TX's. I do know there are various types of Frequency Recognition systems on our equipment. There have been several version and revision to the equipment. I have Futaba, JR, Spectrum, several Chinese versions (FrSky and Turnigy), and Hitec TX systems. I have had problems with all. But I have had great success with all as well. I would not rank anyone above the other. They all have had improvements and at this point it is just a matter of cost. If paying $400+ for a TX makes you feel that you are getting a bullet proof system then buy it. I can get the same results from a 72 MHz TX ($9.00 on ebay) and a conversion kit that will cost me $35.00.
Each generation of TX is getting better and just like video recording - Beta tapes were much better than VHS, but the cost was 3 times as much. At the end of the day VHS tapes won the battle of shelf space at retail markets. So for now, DSMX is leading the pack in sales due to price.
rcflyertim is offline Find More Posts by rcflyertim
Old Mar 19, 2014, 06:55 AM
geofrancis is offline
Find More Posts by geofrancis
nothing is unfixable
United Kingdom, Scotland, North Ayrshire
Joined Feb 2010
i have never had any problems with any of the 2.4ghz stuff i use. HKT6A 6ch and frsky module in my 9x.
that being said user error or power issues have caused lots of problems over the years:
from not using a big enough BEC and the receiver browning out
the antennas not being screwed on tight enough
battery connectors vibrating loose
receiver antennas inside the plane too close to the motor wires
geofrancis is offline Find More Posts by geofrancis
Old May 19, 2014, 03:45 PM
Ilikeedfs is offline
Find More Posts by Ilikeedfs
One does not simply fly RC...
Ilikeedfs's Avatar
Joined May 2014
Ive never had any problems with my TX or RX equipment, other than bad batteries, but I've never really pushed it (Other than the range test I did in my house, plane in one corner of the house, me in the other) I'm guessing it could be interference, or at 150 feet and 200 feet away there might have been some kind of wind that too you down.
Ilikeedfs is offline Find More Posts by Ilikeedfs
Old May 03, 2015, 08:34 AM
rmorrow is offline
Find More Posts by rmorrow
fort stockton texas
been there and done that
Originally Posted by PlotShots View Post
Guys, this past weekend, my brand new Tiger 2 lost its life due to what can only be described as "shot down" from interference...
Take-off was normal and true. I turned left to have it come back towards me. No issues. It was cruising at approximately 40 mph and straight-and-level. It had reached an altitude of about 150 feet and was passing by me about 200 feet away and 150 feet in altitude. THEN, it turned right, flipped upside-down, and lawn-darted into the field. Control inputs of any kind were useless in the 1.5 seconds it took to hot the ground.
Here are some specs on my equipment:
-2.4 G Spektrum DX7S
-O.S. 55 AX
-CG Tiger 2
-JR On/Off switch
-1,900 mAmp battery pack with 90% capacity verified post crash.
-5th flight of its life. Previous 4 flights had no issues.
Here's a picture I took just after its maiden flight from last week:
Attachment 5972542
So what the hell happened?! Are 2.4G radios DANGEROUS???
i have had several hits with total loses, the planes act just as you describe
i have done a little research and it is probably a cell phone jammer
i would love to catch the bh
rmorrow is offline Find More Posts by rmorrow
Old May 03, 2015, 02:32 PM
Joined Aug 2008
Vanishing redundancy.
Originally Posted by rmorrow View Post
i have done a little research ..............................
So have I.
This link explains in technical terms the vulnerability of the Spektrum/JR system:
http://www.rcmodelreviews.com/dsm2flaw.shtml
In simple terms, it has almost vanishing redundancy and is vulnerable to interference.
Old May 03, 2015, 04:43 PM
Joined Feb 2010
i would always check your power systems first before blaming the radio. an over loaded bec or poor connection somewhere is far more lightly.
Old May 04, 2015, 08:15 PM
ronaldopn is offline
Find More Posts by ronaldopn
ronaldopn's Avatar
Brazil, RJ, Rio de Janeiro
Joined Oct 2012
Funny part is that I still have the Beaver in pieces in the garage yet to fix. Got busy with buying another house, moving, life, etc., etc.
I plan on getting going again in a couple of months... And continue the investigating with this particular DX7s... Static tests only, tho. I don't like the thought of putting my property or others at risk until I verify what's going on.
Hi, I guess I'm a bit late to this thread but I'd suggest you install your receiver in a simulator (wireless preferably). This way you can detect failures without risking anything.
I lost one plane due to an apparent loss of signal (all controls frozen). After a lot of discussion and research without finding the issue I just swapped the receiver with the one on my wireless sim and started flying again (very reluctant).
To my surprise (and relief) it took me only a few flights on the sim to detect a receiver problem.
I still have the receiver and it still acts weird but at least I know it will never shoot me down again.
Radio is a Frsky Taranis X9D which I love
Crash details and video here:
http://www.rcgroups.com/forums/showthread.php?t=2280825
Good luck with your troubleshooting, I know how frustrating it can be
ronaldopn is offline Find More Posts by ronaldopn
Old May 31, 2015, 09:32 PM
Topdogzrc is online now
Find More Posts by Topdogzrc
Wanted: More Time to Fly
Topdogzrc's Avatar
Joined Aug 2014
I wonder how many of the issues are caused by bad electronics/boards failing in the radios versus the coding protocol like DMSS/DMSX/FHSS...
I had my DX6 crash my UMX MiG after it locked out and the transmitter showed zip signal with the telemetry. Tried another model and still dead signal. Sent it in to make sure the suspected bad board gets fixed.
My DX7S still works flawlessly, so using it in the meantime.
On another note, I heard Spektrum runs on a higher voltage than other systems. Can somebody confirm this?
Topdogzrc is online now Find More Posts by Topdogzrc
New Product WFLY 2.4G 7channel Mini Receiver Match all wfly 2.4G remote control longboss Radios 0 Apr 19, 2013 08:30 AM
New Product WFLY 2.4G 7channel Mini Receiver Match all wfly 2.4G remote control longboss Hot Online Deals 1 Apr 19, 2013 05:34 AM
Discussion T28 Shot Down ... On Cajun Pawn Stars mybad Electric Warbirds 5 Jan 13, 2013 11:04 PM
Shot Down By A Rocket? Buzz Parkflyers 29 Apr 23, 2007 09:10 AM
