Old Jul 17, 2013, 02:10 AM
rcminiman is offline
Find More Posts by rcminiman
Scotland
rcminiman's Avatar
Help!
Walkera 4#3 wont stay in the air. Power keeps dropping.
Hi folks,
Ive been enjoying flying my 4#3 recently, but it has always had a bit of a problem in that it always required more throttle to be added during the flight until It was eventually maxed out and it would sink to the ground.
It has now begun doing this even worse, to the point it wont even lift off more than a few feet before sinking.
It has new batteries, and I have even tried Turnigy high discharge to see if it was the voltage dropping through current pull. This made NO difference at all.
The motor has only had a few flights on it, and was working ok. Its never been overheated due to long flights.
Is this a fault with the 4 in 1 or the motor? weird......
rcminiman is offline Find More Posts by rcminiman
Old Jul 17, 2013, 09:00 AM
Balr14 is online now
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
I never had a 4#3 motor last much longer than 1 hour, some far less. It's unlikely that it would be the board; FETs (speed controller) work or don't work.... they don't slow down. As far as I recall, there's not much else on that board but 2 FETs, a gyro and receiver. You might try a motor from the Genius. That was the longest lasting Walkera motor I ever owned, by a wide margin.
Balr14 is online now Find More Posts by Balr14
Old Jul 17, 2013, 10:07 AM
Scotland
rcminiman's Avatar
I have another motor that I could try out.
It just seemed weird that it will fly again straight after dropping to the ground only seconds prior.
Old Jul 17, 2013, 11:39 AM
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
You didn't say that it would fly fine after losing power. Another possibility is the battery connections and soldering. I recall having to replace connectors with something that had better contacts and having to resolder the battery cable connections on the board. I think this was pretty common, too. It's been about 5 years since I had a 4#3, so it's real hard to remember.
Old Jul 18, 2013, 02:17 AM
Scotland
rcminiman's Avatar
Well, when you say it flys fine after losing power, it does exactly the same again.
I take off, plenty of power, then it slowly loses power over the course of say 20 seconds, and drops to the ground again.
I will hunt for a bad connection or broken strands etc. It could make sense if a connection was heating up and increasing resistance. I will have a better look.
I will also ask my FET specialist at work here and see what he thinks. We use them to control the output on the protection boards on battery packs we make here.
Discussion Firebird Statos Keeps Turning Left in Air ShowTime88 Parkflyers 29 Jan 09, 2014 02:38 PM
Help! Spektrum wont stay bound mx_ata2d Radios 6 Mar 15, 2013 01:43 PM
Discussion s107 wont stay in the air fball1208 Coaxial Helicopters 6 Jan 15, 2012 06:47 PM
Discussion MSR 5-in-1 amd Walkera 4#3B 4-in-1 Electronics Swap and keeping it lightweight EQMOD Micro Helis 24 Feb 19, 2011 05:57 PM
Hummingbird wont stay in air hayre Micro Helis 24 Oct 28, 2003 01:20 PM
