Old Dec 23, 2012, 11:28 PM
georgy is offline
Find More Posts by georgy
Allways the hard way!
georgy's Avatar
South Africa, GP, Germiston
Joined Jan 2012
Question
Servo-guts as drive in mini sub
Read somewhere a bloke used std servo insides as a drive motor & ecs for his mini sub... can any-one tell me how I can do that?
2nd... looking for details on WTC for 1:144 sub... (pics removed from tread i found!)
Maybe bit off more than i can chew with this little thing (Trumpeter Chinese #33)
Any help to noob appreciated...
George
georgy is offline Find More Posts by georgy
Old Dec 24, 2012, 01:01 AM
redboat219 is offline
Find More Posts by redboat219
Philippines
Joined Jan 2005
1/144 Trumpeter Romeo RC conversion
http://translate.google.com/translat...om%2Fepg800%2F
strange, the link doesn't take you to the exact page I was looking at.
Just click on the Building Threads to see the Type 33 plus other model sub kits converted to RC.
redboat219 is offline Find More Posts by redboat219
Old Dec 25, 2012, 12:24 AM
Aeroengineer1 is offline
Find More Posts by Aeroengineer1
Mesa Falcon Fld, Arizona, United States
Joined Sep 2004
You can modify some servo guts for driving a standard motor. The one question is what is the reason that you want to do it? If you were like me when I first did it, I could not afford the $30-40 for a small brushed ESC at the time, but now the costs have come down and my income has come up. If that is the reason that you are doing it, then I encourage you to do it. There are two ways of doing it. The first is to use the pot that is with the servo. You will need to get it positioned so that when your stick is in the neutral position there is no output to the motor. Once in place, I would use some glue to keep it there. The other option is to get a small trimmer pot. The type that is meant for making small adjustments and keeping its place. I would recommend the sealed type. Install it the same way that the other pot is installed. The last option is to use two well matched resistors and solder them in a voltage divider configuration (this is all the pot is doing anyway). This should give you a few options to keep it cheap.
If you are not doing it because you are trying to save some money, there is a small esc that I saw a few weeks back that I was thinking about getting for a small project of mine that is about $20USD. I saw it on ebay, and I went to his web site. he does stuff with RC subs already.
Adam
Aeroengineer1 is offline Find More Posts by Aeroengineer1
Old Dec 26, 2012, 03:58 AM
georgy is offline
georgy's Avatar
Joined Jan 2012
hi Adam
Not really a cost saving issue... it just looked like a cool idea... & small enough to fit into that (VERY) tiny space! Got some small brushed esc's, but they are ex-plane & does not have reverse.
Still shopping for some more ideas... especially the WTC for such a small sub.
The idea is to only do a surface runner for now..
Thanx for the help..
George
Old Dec 26, 2012, 03:13 PM
herrmill is offline
Find More Posts by herrmill
Shanghai'd Expat
herrmill's Avatar
Xiaoshan, China
Joined Jun 2006
You may want to consider something like Rick @ Scale Model Castings does for his micro sub kits. I have one of his 1:22 Marders & would recommend looking over his site & related photo gallery for some ideas on best to approach your project. His Marder / torpedo kits would probably do the trick but he also does custom work if you're inclined to buy a WTC
http://www.scalemodelcastings.com/Ne...-kit_p_20.html
http://scalemodelcastings.smugmug.co...1528&k=ngpnLsT
herrmill is offline Find More Posts by herrmill
Old Dec 28, 2012, 08:17 AM
Sub culture is offline
Find More Posts by Sub culture
Man from Atlantis
Sub culture's Avatar
London
Joined Nov 2003
Something worth bearing in mind if using a servo amplifier as a speed controller. They tend to pulse the output at a maximum of 50% duty cycle, and if analogue at a 50hz rate. That means your motor doesn't see maximum power.
An ESC will give 0-100% duty cycle, and at a frequency rate better suited to good low speed control.
Sub culture is offline Find More Posts by Sub culture
Old Dec 28, 2012, 10:23 AM
georgy is offline
georgy's Avatar
Joined Jan 2012
Been looking at the "bottom drawer-13"... found a brushed esc & 300 size motor doing nothing... Think this will suit the job better. Will have to make a custom battery pack to suit the space available.
Big thing now is to build a WTC & fit the plastic kit around the WTC. Want to fit all electrics with controls and drive shaft as a stand-alone piece & then fit the scale bits onto that....
PS: Gave up on the type-33 Chinese sub. It's just too small. Got a Trumpeter Seawolf 1:144. MUCH bigger space to work with.
As a sub-noob i thought one challenge at a time
Thanx for the help gents...
George
Discussion Are Thunder Tiger ACE mini servos the same thing as Solar mini servos? Atomic Skull Large Electric Helis 0 Dec 22, 2012 12:47 AM
Help! Mini Multirotors sub-forum in the Multirotors forum Vote Please! jesolins New Forum Requests 67 Dec 17, 2012 12:20 PM
Discussion Kukorelli Glamour EVO V.2 (flex drive) Mini Eco Expert - first in North America northernmike Racing Boats - Electric 8 Nov 12, 2012 01:25 PM
Sold Art-Tech AS-100 Sub-Micro & AS-170 Micro Servos N925WB Aircraft - General - Radio Equipment (FS/W) 3 Mar 21, 2006 07:17 PM
