Old Jun 05, 2010, 12:56 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Simultaneous LVC Cutoff of Twin Motors Using Smart BEC
In my present ME-262 setup, one of my two ESC's will go into LVC and cut one motor, the other ESC and motor continue to run with unplanned aerobatics and loss of control due to assymetric thrust. I have to avoid LVC or cut throttle instantly and regain control for dead stick landing if high enough or keep flight times short to avoid the problem
I have been told that Dimension Engineering's Smart BEC has an LVC circuit that can be used to cut both motors at the same time when motor battery voltage sags. Trying to get specific how to wiring information from Dimension Engineeering, Castle Creations and other E-Zoners. I think this is important stuff for any multi-brushless-motorered EDF or prop model
Here's my thread with a wiring diagram, I think that I'm almost there:
http://www.rcgroups.com/forums/showt...2#post15245895
E-Challenged is offline Find More Posts by E-Challenged
Old Jun 05, 2010, 09:43 PM
Daedalus66 is online now
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
If you EVER see LVC you are not managing power correctly. Every time you hit LVC you damage the battery. And the damage is cumulative.
By timing your flights, measuring resting voltage carefully and noting the amount you put back into the battery when charging you can ensure that you never use more than 80% of the battery capacity. That way batteries can last years.
Daedalus66 is online now Find More Posts by Daedalus66
Old Jun 06, 2010, 10:27 AM
Joined Oct 2000
I don't need "Power Management 101 for Newbies" . I have been doing exactly as you recommend keeping flights short enough to avoid possiblity of LVC one motor out. You should know that lipo packs in EDF's are typically stressed a lot and will change capacity and duration over time so that the LVC thing can happen, especially if you have to "go around" a couple of times due to other traffic after a 4 minute flight. I just wanted to share something that would offer a measure of protection for multi-brushless EDF's and prop planes.
Discussion Simultaneous LVC Two T-Bird 36's and Smart BEC E-Challenged Castle Creations 1 Jun 04, 2010 05:37 PM
Discussion Blade mSR does NOT like cold weather - Premature LVC cutoff hydro_pyro Micro Helis 4 Jan 30, 2010 09:26 PM
Discussion Use of Switching BEC with twin EDF motors/esc's E-Challenged Electric Ducted Fan Jet Talk 0 Jan 07, 2010 12:41 PM
Sold Dimension Engrg Smart BEC with Lipo cutoff, NIB! JREEVES Aircraft - Electric - Power Systems (FS/W) 0 Dec 30, 2008 02:31 PM
Alert Phx 10, LVC cutoff when using both 2c and 3c lipoly? Ronbo Castle Creations 4 Jun 16, 2004 02:57 PM
