Old Jul 16, 2015, 07:57 AM
davehealy is offline
Find More Posts by davehealy
Joined Jul 2015
Question
Getting started with Powerlab8, Powerstation and Tattu 16000 mah batteries
Hello
I'm new to all this, and would appreciate any/all constructuive suggestions!
So I have my Powerlab8 with EC5 connector on the input; I need to connect this to the power supply (PowerStation); do I just snip off the EC5 and put the bare wires into the 24V terminals at the back of the PowerStation?
The Powerlab8 comes with the SPA adapter. The balance lead from the Tattu 16000 battery has a 7-pin plug, with one red lead and 6 black. Which way around does this plug into the SPA adapter?
I've soldered AS150/XT150 female plugs on to the battery leads, ready for my DJI S1000+. Can I now solder XT150 male leads onto the Powerlab8 output leads to improve charge time? (i.e. not just run with the balance lead only).
Thanks in advance,
Dave
davehealy is offline Find More Posts by davehealy
Old Jul 16, 2015, 02:14 PM
Gregor99 is offline
Find More Posts by Gregor99
Seattle
Joined Sep 2007
For the power station, I would make an EC5 pigtail, strip the wires on one end then connect that to the posts on the power station. Then connect the EC5 on the charger to the pigtail.
For the Spa you will need to be JST-XH wiring mode which requires the balance leads AND the main leads. So yes, build a cable to as you described.
For balance pin orientation the SPA as text stenciled on to help. See below.
Other useful info
FAQ - Powerlab Quick Start Guide - Wiring modes, Supply Limits and 1s charging
Gregor99 is offline Find More Posts by Gregor99
Old Jul 16, 2015, 03:08 PM
Joined Jul 2015
Thanks for that; much appreciated.
Dave
Wanted Tattu 10000 or 16000 mAh 22.2v thanks POWERFTK Aircraft - Electric - Batteries & Chargers (FS/W) 1 Feb 22, 2015 05:42 AM
Wanted Tattu 10000 or 16000 mAh 22.2v 15C POWERFTK Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 09, 2015 02:16 AM
For Sale Tattu 6s 16000 & 10000 Batteries Brand New 0 Cycles atrocity123 Aircraft - Electric - Batteries & Chargers (FS/W) 6 Nov 17, 2014 01:13 PM
Sold Gens Ace Tattu 16,000 mAh 6S LiPo Battery ryancanon Aircraft - Electric - Multirotor (FS/W) 6 Nov 10, 2014 10:42 AM
Sold 2xGens Ace Tattu 10,000 mAh 6S LiPo Battery ryancanon Aircraft - Electric - Multirotor (FS/W) 7 Nov 01, 2014 09:26 PM
