Old Apr 20, 2015, 03:14 PM
erospawn is online now
Find More Posts by erospawn
United States, NC, Cary
Joined Aug 2010
Habu2 Recommended EDF -- Originally posted in Power Systems
Hey All,
My goal is to get the great whoosh sound that you get with higher blade counts on these edf units. What I am looking for is a fan unit with 10-14 blades that will work with the Eflite stock motor that will work with the Habu 2. THis is what I've found that I think will work. But, if any of you know or have actual experience, that would be awesome as well.
Does anyone know if this will need to be balanced etc?
http://edfhobbies.com/index.php?rout...product_id=319
erospawn is online now Find More Posts by erospawn
Old Apr 20, 2015, 03:38 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
You might check out theses threads:
Habu 2 Owners thread.All mods/tips,upgrades info,Vid links- post 1
http://www.rcgroups.com/forums/showt...ghlight=habu+2
Parkzone Habu!
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Apr 20, 2015, 04:28 PM
efflux RC is online now
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Originally Posted by erospawn View Post
Hey All,
I changed out the rotor on my modified 6s setup, and ran it on 5s with the Wemo minifan EVO. (9 blades)
You would need the one that takes a 4mm shaft.
These fans come with a balanced rotor, but final dynamic balance after EDF/motor assy is preffered. If you have experience you can do it. Or I can do it for you.
Sounds great and only requires a 7% lower kv motor if you want to keep the amps the same. Most folks run them with the same motor. The stock Habu motor is 3200kv. It will be fine with the EVO EDF unit. on 4s. Not sure what ESC comes with the Habu 2, If it's 60A you should be fine.
For more power on 4s, many folks run the HET 2W-20 (3400kv) with the EVO fan and a 75A ESC.
There's a couple of my Habus in the upgrades thread that cooler posted.
efflux RC is online now Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Apr 20, 2015, 06:55 PM
Joined Aug 2010
Thanks Eflux RC. Ideally I would like to continue using a 4s as I have several 3300 50C's , but I do have some 6s 3500's 35C as well. So it sounds like you have what I am looking for and I will definitely need you to dynamically balance the unit seeing as how I do not have the equipment to do that.
How much flight time would I end up getting if I stuck with the 4s? I'm trying to achieve the same power, flight time roughly, while getting the nice whoosh sound as well.
Old Apr 21, 2015, 12:06 AM
efflux RC's Avatar
Joined Aug 2009
Your current lipos would get just a little less time than you are currently seeing with your flying style (whatever it may be.) The standard battery for the Habu 2 is 3200 mAh, I believe. the stock Eflite rotor is actually more heavily loaded than say the standard, Wemo mini fan (6 blades). So you won't be to far off.
6s takes lots of mods to make it work. A good middle of the road 4s/5s setup (with the 3300kv, HET 1W-40 motor) is easier to do. and keeps the jet lighter. There's lots of tips regarding how to mod the Habu in the "Habu 2 owners" thread.
Just for kicks, Here's my 6s Habu with the Standard minifan rotor on 6s. Nothing official as far as averaged upwind down wind speed passes. Just messing around with the radar gun. Radar runs start around 5 mins into the video. I was manning the Radar gun , not the camera.
Habu 2 RADAR runs...best pass: 142mph (10 min 52 sec)
Site Sponsor
Old Apr 23, 2015, 03:12 PM
whisperdancer is online now
Find More Posts by whisperdancer
Portugal, Porto District, Maia Municipality
Joined Aug 2008
The wemo evo fan seems a good bet for the stock motor on 4s.
whisperdancer is online now Find More Posts by whisperdancer
Discussion HURC GWS 64mm 3900kv EDF Power System bansheerider Electric Ducted Fan Jet Talk 0 Dec 10, 2014 02:28 PM
Sold Used 90mm EDF Power System from a Stinger 90: EDF/Motor, 100A ESC, & 8A/15A BEC T-CAT Aircraft - Electric - Jets (FS/W) 5 Aug 04, 2014 10:32 PM
Sold New 90mm EDF Power System from my Stinger 90: EDF & motor,100A ESC, and 8A/15A BEC T-CAT Aircraft - Electric - Jets (FS/W) 3 Apr 09, 2014 12:49 AM
Sold Brand new EFlight power system from Foam Habu2 fh64_lucky Aircraft - Electric - Jets (FS/W) 3 Aug 02, 2012 12:50 PM
Discussion twin EDF power system recommendations Viking goes Thud Electric Ducted Fan Jet Talk 4 Mar 04, 2011 01:35 PM
