Old Jun 22, 2013, 01:22 AM
Marlbororman is online now
Find More Posts by Marlbororman
United Kingdom, England, Hull
Joined Aug 2011
I built mine entirely from 6mm depron. Materials are do2n to the individual I think.
Marlbororman is online now Find More Posts by Marlbororman
Old Jun 24, 2013, 09:40 PM
Zero Six Sierra is offline
Find More Posts by Zero Six Sierra
Zero Six Sierra's Avatar
United States, IL, Chicago
Joined Jun 2002
Can anyone say FunJett clone EDF!!!
Will be using a 64mm fan with a 3S 2200mAh
More coming soon!
Zero Six Sierra is offline Find More Posts by Zero Six Sierra
Old Jul 08, 2013, 02:47 PM
ProjectFlightDes is offline
Find More Posts by ProjectFlightDes
Joined Mar 2013
Originally Posted by Javatango View Post
Has anyone tried a build with 1" pink foamboard for the center section? I cannot find the 1/2" foam board locally.
What are you going to use for the wings? Perhaps you could use that same material.
The only reason I ask is because I sandwiched the wing between the 2 fuse halves
ProjectFlightDes is offline Find More Posts by ProjectFlightDes
Old Jul 08, 2013, 11:19 PM
Javatango is offline
Find More Posts by Javatango
United States, WA, Auburn
Joined Dec 2011
I ended up using the 1" thick pink foam board from Home Depot for the top and bottom. It's a PITA to make clean cuts with foam this thick. The plane turned out OK for my very first foam build from scratch. I am a bit concerned that the extra thickness may block air to the 5x5 prop. I will find out soon enough as I plan to maiden the plane on Friday.
The orange "tape scheme" was inspired by another builder on this thread.
Description: Name: IMG_20130707_210931.jpg
Description:
Javatango is offline Find More Posts by Javatango
Old Jul 09, 2013, 10:53 AM
Joined Mar 2013
Looks great! As long as, like you mentioned, that the prop doesn't get air starved behind the fuse
Old Jul 09, 2013, 01:16 PM
Joined Aug 2011
should be ok like that, my first one is as thick formed as that after trying to fly and crash, getting cg correct. flys superb too building another the same now i know its ok.
New Product "Light" Funjet for FPV still lives! Old Funjet clone at HobbyKing! nk4787 FPV Talk 0 Oct 25, 2011 02:04 AM
Discussion Has anyone tries a funjet clone from 6mm superinstaller Pusher Prop Jet Models 1 Nov 24, 2009 05:59 AM
Sold Funjet, MJ clone, Twinjet....getting out of hobby Eagle50 Aircraft - Electric - Airplanes (FS/W) 3 Nov 01, 2009 11:27 AM
For Sale Funjet, MJ clone and Twinjet Eagle50 Aircraft - Electric - Airplanes (FS/W) 2 Jul 27, 2009 05:22 PM
Sold Projeti, Velocity, Funjet Microjet clone!!!!!!!!! Eagle50 Aircraft - Electric - Airplanes (FS/W) 13 Mar 25, 2009 03:59 AM
