Old Jan 16, 2013, 02:08 PM
serbcccc3 is offline
Find More Posts by serbcccc3
USA, TX, Houston
Joined Jan 2011
Old electric brushed motor found
OK... i know this will be a long shot, but i though i would ask just for the hell of it.
I found 2 old electric rc motors from an RC car I had probably over 15 years ago. Neither of them really have any markings identifying them except one of them indicates its a 12 turn motor. I connected 6 volts as a test directly from a battery to each of the motors to see if they even still run and they start spinning just fine.
So my question is this... is there any way to determine what type of motor driver (or brushed esc) i could use for these motors? I have a dc motor controller i use on one of my 6wd off road robots that can produce up to 15amps max on 2 motors (its a wild thumper motor controller (arduino based)).
I didnt want to hookup anything to these under a load without knowing their current draw but dont really know where to start.
Thanks in advance.
Marko
serbcccc3 is offline Find More Posts by serbcccc3
Old Jan 16, 2013, 02:29 PM
SoloProFan is online now
Find More Posts by SoloProFan
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Usually a 12 turn motor will draw more than 15 amps. Unless this speed controller has built in protection against overheating or excess current draw, I doubt it will survive running this motor in a car.
SoloProFan is online now Find More Posts by SoloProFan
Latest blog entry: Pictures of various boats
Old Jan 17, 2013, 12:33 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Current draw will depend on the load on the motor, which will depend on the gearing, weight of the vehicle, etc.
wparsons is offline Find More Posts by wparsons
Old Jan 23, 2013, 03:37 PM
JUANJOARCHILLA is offline
Find More Posts by JUANJOARCHILLA
JUANJOARCHILLA's Avatar
Spain, Community of Madrid, Madrid
Joined Jun 2009
12 turns was medium motors, not the hottest but anyway stall amperage will be easily over 10 amps, and working without any load it would be around 3 to 4 amps if not advance in endbell has been done. If some advance has put via turining endbell or under load, this can go without any problem in the area of 6 to 10 amps. So the only way to safely run this motors is with an appropiate rc esc
cheers.
JUANJOARCHILLA is offline Find More Posts by JUANJOARCHILLA
Discussion Brushless electric motors for selected old timers JohnAV8R Vintage & Old-Timer Designs 44 Apr 17, 2015 12:49 PM
Sold Old School Brushed Motors & Speed Controls dls Aircraft - Electric - Power Systems (FS/W) 3 Oct 25, 2012 05:34 PM
Found --found/closed/thanks rcfanatic--Brushed r/c car ESC that can handle 11.1 lipo fly_right Cars - Cars and Parts (FS/W) 6 Apr 14, 2012 07:39 PM
Sold Brushed motors/esc and old batteries/charger Scotch029 Non R/C Items (FS/W) 3 Mar 20, 2012 12:45 PM
Sold Parkzone Motor for Spitfire...the old version of the Spitfire with a brushed motor mondo1948 Aircraft - Electric - Power Systems (FS/W) 0 Mar 03, 2012 07:23 PM
