Old Oct 27, 2012, 01:53 AM
hakank is offline
Find More Posts by hakank
Sweden (┼kersberga)
Joined Nov 2004
Carbon fuse compatible rx (Spektrum)
What is the technical difference between a carbon compatible rx vs a standard?
I'm planning for a smaller Pylon project in carbon and thinking of different alternatives like maybe have the antenna to stick out from the fuselage. Or purchasing a carbon compatible rx.
Thanks!
hakank is offline Find More Posts by hakank
Old Oct 27, 2012, 07:38 AM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
On carbon (carbonfabric/epoxy) fuselage - you need to get antenna well away from the carbon surfaces and outside as well
Does not matter which brand radio - This can be a of work but if you use some small stiff tubing guides - you can stick one out each side the model . OR tape each whisker to underside of wings as far out as possible. --providing the wings are not carbon fiber .
The difference in the rx is typically, the extended coax which allows you to move the actual recptive part (the exposed wire) well away from the carbon.
richard hanson is offline Find More Posts by richard hanson
Old Oct 27, 2012, 10:13 AM
hakank is offline
Sweden (┼kersberga)
Joined Nov 2004
Thanks, clarify things. So basically the old AR500 with one long whisker could be an alternative?
Old Oct 27, 2012, 10:34 AM
Joined Oct 2007
well--- not really- It has one long wisker and a short one so on a small model model - flown in close -you may be ok but the possibility of blanking out both -from the carbon fuselage -- is real.
On a fast pylon racer - I would not do it .
Old Oct 27, 2012, 12:54 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
One of my friends flies pylon racers a lot. He has used the AR6255 for the longest time. Having pre-set failsafe on all channels was important to him.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Discussion Spektrum ar6255 Carbon fuse rx smokinjoe22 Radios 12 Oct 03, 2012 01:54 AM
Sold 2 x Spektrum AR6255 and 1 x AR6250 Carbon Fuse Rx's jgalexander Aircraft - General - Radio Equipment (FS/W) 11 Jun 20, 2012 06:08 AM
Sold Spektrum 6255 Carbon Fuse RX lafuerza Aircraft - General - Radio Equipment (FS/W) 5 Mar 14, 2012 06:11 PM
Sold TWO SPEKTRUM AR6255 RX's (CARBON FIBER FUSE) NIB burke757 Aircraft - General - Radio Equipment (FS/W) 2 Sep 27, 2010 04:35 PM
For Sale Spektrum DSM2 6-Ch Carbon Fuse Rx jofo1 Aircraft - General - Radio Equipment (FS/W) 1 Mar 08, 2010 04:32 AM
