Old Feb 23, 2012, 08:41 AM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Longer wires to Power or to Motor?
I need to make a long run to motor for a Quad copter.
I want to get my ESC off the arms.
I can lengthen the 2 power wires
or
Lengthen the 3 brushless motor wires
Which is best and why?
Motors pull about 10A in a hover and about 20A max
My preference is to put the ESCs at the ends to get the weight out near the tips for stability and airflow and to De-clutter the central area. Then solder on longer power wires to run the power through the arm tube to hide wires.
thx
Melnic is offline Find More Posts by Melnic
Old Feb 23, 2012, 08:46 AM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
http://www.rcgroups.com/forums/showthread.php?t=952523
jkettu is offline Find More Posts by jkettu
Old Feb 23, 2012, 11:47 AM
Vipula AD is offline
Find More Posts by Vipula AD
Vipula AD's Avatar
Greensboro/H.Pt/Win-Salem P.T. Intl, North Carolina, United States
Joined Dec 2001
or
thx
Rule of thumb;
Length of wire from battery pack to ESC < 12
Therefore, for any longer length of connections, increase wire from ESC to motor.
Vip.
Vipula AD is offline Find More Posts by Vipula AD
Old Feb 26, 2012, 06:56 AM
mchldpy is offline
Find More Posts by mchldpy
CLMAMA 962750
mchldpy's Avatar
United States, CA, San Bernardino
Joined Feb 2010
you could go the "xtra caps" routine inline to stop the "ripple effect" (the surging caused by the esc switching off and the voltage spiking... longer wire = higher spikes so longer wire needs more caps of same or higher value)
michael clyde
mchldpy is offline Find More Posts by mchldpy
Question To extend speed control wires ? motor or battery side ? Dennis Everett Power Systems 5 Oct 17, 2011 05:05 PM
Question Solder or use bullet connectors when making my ESC wires longer justy g Power Systems 4 Sep 29, 2011 08:02 PM
Help! Motor squeels and stops when throttle quickly applied Longer wires the cause??? planebldr Power Systems 6 Jun 20, 2010 04:17 PM
Cool What to extend? Motor wires or Battery wires? L0stS0ul Castle Creations 16 Sep 18, 2006 02:39 PM
Question Twin CC Phoenix 10 - lengthen battery wires or motor wires? Rich_N Castle Creations 5 Sep 20, 2005 12:22 PM
