Old Jul 25, 2011, 03:19 PM
ServoCity is offline
Find More Posts by ServoCity
ServoCity's Avatar
United States, KS, Winfield
Joined Jun 2011
Data
Servo Protractor - $17.99 - In stock!
Servo Protractor from ServoCity.com ---
Now you can set up multiple digital or analog servos to the exact same angle. Our Servo Protractor is very easy to use and is accurate to 1 degree. Simply take the horn/arm off of your servo, place your servo in the back of the Servo Protractor and align the servo against the aluminum spacer. The spacer is in place so that each servo you program is set exactly the same. The spacer can also be adjusted for various size servos. This unit is recommended for Hitec analog and digital servos. Works with standard 24 tooth Hitec spline only.
http://www.servocity.com/html/servo_protractor.html
ServoCity is offline Find More Posts by ServoCity
Site Sponsor
New Product Hitec Minima 6T Micro Rx - now in stock at ServoCity.com - $44.99! ServoCity ServoCity.com 0 Jul 20, 2011 08:59 AM
For Sale Boeing PT-17 Stearman Kaydet 40 - 44" for $99 richyan Aircraft - Electric - Airplanes (FS/W) 0 May 31, 2011 03:28 PM
Discussion Props 17.7/17.5 with 32,36 and 38mm spinners--In stock! sneu High Performance 0 Jun 14, 2010 05:51 PM
Alert Flightmax 3s 20c 2200 lipos $17.99 @ Hobbycity 1849 in stock............. mtdoramike Hot Online Deals 11 Jun 01, 2009 07:51 PM
Discussion Parawing $17.99 ----parawing/car/boat $24.99 LOGICAL_PSYCHO Hot Online Deals 0 Dec 26, 2006 05:56 PM
