Old Apr 01, 2011, 02:39 PM
nexstarselect is offline
Find More Posts by nexstarselect
Azerbaijan FPV
nexstarselect's Avatar
Joined Nov 2009
Futaba 8fga and Dragonlink
Hello how i can Connect dragonlink futaba8fga via treiner port it'll work?
nexstarselect is offline Find More Posts by nexstarselect
Old Apr 01, 2011, 04:12 PM
ThomasWF is offline
Find More Posts by ThomasWF
ThomasWF's Avatar
UK, Sussex.
Joined Nov 2005
No, it outputs a signal and it will move a servo but won't work properly as it does't output PPM. Tried mine, failed, got a cheap 7c.
ThomasWF is offline Find More Posts by ThomasWF
Old Apr 01, 2011, 04:26 PM
ripdog is offline
Find More Posts by ripdog
USA, LA, Shreveport
Joined Feb 2011
So I can use the tport on my futaba fm 7ch only and will not have to open the back and solder??
ripdog is offline Find More Posts by ripdog
Old Apr 01, 2011, 05:28 PM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
http://www.rcgroups.com/forums/showp...postcount=8814
Ian Davidson is offline Find More Posts by Ian Davidson
Old Apr 01, 2011, 06:09 PM
ThomasWF is offline
ThomasWF's Avatar
UK, Sussex.
Joined Nov 2005
I opened my 7c and spliced a servo socket onto the ppm, + and - that go to the TX board then removed the crystal., works a treat.
Old Apr 01, 2011, 08:04 PM
lilphil26 is offline
Find More Posts by lilphil26
Toronto Canada
Just curious How Thomas couldnt get it to work with the 8fg, but Ian did, with no problems at all.
lilphil26 is offline Find More Posts by lilphil26
Old Apr 02, 2011, 02:57 AM
ThomasWF is offline
ThomasWF's Avatar
UK, Sussex.
Joined Nov 2005
Would live to know how, I just need one more channel so using my 8FG would make life so much easier.
It does kinda work, the servos move pretty much how they should and you can stop it transmitting on 2.4 by holding the middle of the circle on power up - but the servos don't move to their full extents and sort of drift - if you look at the spec it does not do PPM.
Old Apr 02, 2011, 03:41 AM
3frcg is offline
Find More Posts by 3frcg
Joined Jul 2010
Not correct.
T8FG has PPM output at the trainer port.
So no problem to attach the Dragon Link.
3frcg is offline Find More Posts by 3frcg
Sold Futaba 8FGA 8-Channel 2.4GHz Air Transmitter and R6008HS 8-Channel Receiver $350.00 mike(ocrc) Aircraft - General - Radio Equipment (FS/W) 7 Oct 13, 2010 10:30 PM
Wanted Futaba 8FGA Woodbender Aircraft - General - Radio Equipment (FS/W) 0 Jun 09, 2010 08:11 PM
For Sale Futaba 8FGA 2.4GHZ Transmitter w/3 receivers rmorris3 Aircraft - General - Radio Equipment (FS/W) 2 Apr 10, 2010 03:23 PM
Discussion Any Interest in the Futaba 8FGA zero2444 Radios 2 Aug 10, 2009 09:17 PM
Discussion Futaba 8FGA 8-Channel 2.4GHz FASST Air R6008HS Mode 2 tune by tito Radios 8 Jul 15, 2009 11:15 AM
