Old May 08, 2013, 12:25 PM
galaxy1 is offline
Find More Posts by galaxy1
galaxy1's Avatar
Italy
Joined Oct 2005
perfetto! se hai bisogno chiedi pure
galaxy1 is offline Find More Posts by galaxy1
Old May 31, 2013, 12:34 PM
SysCrusher is online now
Find More Posts by SysCrusher
United States, FL, Jacksonville
Joined Jan 2013
I have experienced the same thing as our friend galaxy1 has. Can be annoying to all of a sudden getting a wag of death going. Seems to be that only the delay and servo settings are effected as my limits and servo direction settings haven't changed. Yet.
SysCrusher is online now Find More Posts by SysCrusher
Old Aug 18, 2013, 07:23 PM
cgschaefer is offline
Find More Posts by cgschaefer
Woodbridge, VA
Joined Mar 2006
Originally Posted by Jackuzy View Post
Just an update to my problem.
The journey through my gyro-servo problems have just ended. The solution? Get rid of the cheapo esky servo and replace it with "known to work" Corona DS-919MG ;] Now everything is working like a charm ;] ...
So if You think about saving some money and using "your old good digital servo" think again and buy something known to work good ... or You could end loosing time and eventually money You was trying to save to
Thanks guys for trying to help me
Jackuzy, what servo type did you choose for the DS-919MG when you were setting up the DA-250? Does the default setting of 1520us/70Hz work or do I need to reset the type to something else?
Carl
cgschaefer is offline Find More Posts by cgschaefer
Old Aug 19, 2013, 12:02 AM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Could 2 of these be used to run a camera gimbal, or too much drift and jitter etc?
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Aug 21, 2013, 07:39 AM
Pilotrob56 is offline
Find More Posts by Pilotrob56
Pensacola, Fl
Joined Aug 2009
A lot of times when I try and initialize my HT450gt with the ga250 gyro up to my Spektrum dx6i the blue led light on the gyro blinks twice instead of staying on blue. I have to keep unplugging the battery and reinitializing over and over till it has a constant lit blue light. I have hovered it like this but I`m afraid to fly it like this. Does anyone know what I should do or is this normal?
Update: I think maybe I have the radio to close to the heli when I try and link it. Seems like it links up better when I move the radio farther away.
Pilotrob56 is offline Find More Posts by Pilotrob56
Old Feb 05, 2014, 09:27 AM
sikky is offline
Find More Posts by sikky
speedin n da weeds :)
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
What frq setting do I use? And its for a plane rate or hh?
sikky is offline Find More Posts by sikky
Old Apr 14, 2014, 11:53 AM
qcman is offline
Find More Posts by qcman
qcman's Avatar
Canada, ON, Ottawa
Joined Apr 2011
Hi I just installed this gyro on the tail of my Blade 450 with a Turnigy 306G servo. I just can't get this gyro to give me any travel when setting up the travel limits & sometimes it won't move at all. When I set the right rudder travel (closest to tail gears) when I go back to normal it will overshoot that side & bind again.
I would like to set some pitch into torque at center servo but when I do I get no pitch on left rudder at all. Am I doing something wrong or is the setup for travel on this thing just that crappy??
Thx,
Cam
qcman is offline Find More Posts by qcman
Discussion Turnigy Mini Mems/SJGD Mini Mems Programming Box Help jon6565 3D Electric Heli Flying 6 May 15, 2012 01:15 AM
New Product New HobbyKing Mini MEMS Gyro bwoollia Electric Heli Talk 3 Nov 01, 2010 10:16 PM
Question MEMs gyro accuracy BarrelRoll UAV - Unmanned Aerial Vehicles 8 Oct 26, 2007 08:06 AM
