Old Jun 27, 2010, 05:46 AM
ptjw7uk is offline
Find More Posts by ptjw7uk
harwich
Joined Jun 2010
IC to electric power
Hi,
Thinking of converting my old Air SEa rescue boat back to electric power. When I constructed it in the 70,s the electric motors available were pretty low power and noisy! so to get the boat to plane I converted it to a .19 glow motor. It certainly planed well but I was never overy satisfied with the motor, Ok for exercise as it took some starting(new motor)
I now am very puzzled as the motor to fit so it will plane.
I am now suffering from input overload theres just to many variables from the semingly impossible cheap to the just what are you buying expensive.
The model I have is from a MAP plan od a Walton-Thames ASR about 36" long.
Any info welcome as are links.
Peter
ptjw7uk is offline Find More Posts by ptjw7uk
Old Jun 27, 2010, 01:35 PM
420TEE is offline
Find More Posts by 420TEE
North Central TN USA
Joined May 2006
I know just what you mean by overload. You might try the electric go-fast forum but the responses you get from the people who know this stuff will probably confuse you even more. I know it did me.
420TEE is offline Find More Posts by 420TEE
Old Jun 28, 2010, 12:45 AM
nick_75au is online now
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Loolk for E- motors that can handle the equivlant aircraft prop size as a start,
According to quick bit of research a 0.19 can handle a 8*6 to 9*6 propeller.
I think a 700 will spin a prop that size, and there are plenty of brush-less options as well.
The voltage you want to run at, propeller size and RPM will impact on the choice of motor.
Nick
nick_75au is online now Find More Posts by nick_75au
Old Jun 28, 2010, 12:34 PM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Peter,
In the category 'seemingly impossible cheap' there's the fan motor from a car, (the one that cools the radiator), source: scrapheap.
Running one on todays lightweight Lipo's, you should acheive sufficient speed and runtime.
Could you post some pictures and data of your boat, such as total weight and how much you can cram into it before it goes down way over its designed waterline...?
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Discussion Propellor sizing from IC to electric motors camies Power Systems 1 Mar 04, 2010 01:02 AM
Discussion MCU Code Extraction,www.electronicsmade.com ,break IC,crack IC,attack IC minipc Club Talk 0 Nov 22, 2008 01:35 AM
Alert Electric Power vs IC - a newbie thought Red Baron 99 Beginner Training Area (Aircraft-Electric) 6 Aug 01, 2004 11:07 PM
Question Horse Power: IC Vrs Elec frankswd Power Systems 19 Nov 08, 2003 12:26 AM
FS: TwinJet Power System with IC-30 ESC Roger-Roger Aircraft - Electric - Airplanes (FS/W) 3 Aug 02, 2002 10:02 PM
